Alcatel OXE R.9 Common hardware
afeef
Post by afeef »
Dear Alcatel certified Guru’s
Appreciate if you comment your idea’s for following problem.
Alcatel OXE R.9 Common hardware 4 large shelf. Shelf no 3 marked in red color.
When we make internal call from shelf 3 to another shelf couldn’t answer and can’t hear other party voice. But when we call from shelf 3 extension to shelf 3 it’s working fine. And other 3 shelf’s also working fine.
smileyman
Post by smileyman »
Hi afeef,
are the IP-Parameters (Gateway, Subnetmask) correct? Is a ping from the red shelf to another shelf ok (routing)?
Do you have VLAN-config?
Is an error at the call-time in incvisu logged?
smileyman
Shelves 4 and 5 are extension of shelf 3 or 2 ?
afeef
Post by afeef »
Thank you very much smileyman and Frank for your commant.
IP-Parameters and Gateway, Subtetmask is correct. i can ping red shelf to other shelf and other shelf to red shelf.
No VLAN created, actually this is new installation still not completed. i have created 4 extension in each shelf just for testing.
no error logged at the call-time in incvisu?
Yes Frank, Shelves 4 and 5 are extension of shelf 3 or 2 ?
Afeef
freedom
Post by freedom »
Do both shelves have a number of compressors assigned?
Check the No. of Compressors for IP Devices on the GD/GA boards.
If there a no compressors available, you will get a 'silent' call.
Rens
Post by Rens »
Are there any MADA boards present? Are they operational?
Please check with "config all -d". I've seen it on-site where the mada board wasn't fitted correctly. Also no audio.
Rens
afeef
Post by afeef »
Hi Rens
Yes, 1 MADA board in GA card and 1 MADA board in GD card.
Thatks
Afeef
can you show output with "config all" and "compvisu lio" command. For voice you need to declare MADA board and some compressors for IP devices.
afeef
Post by afeef »
Hi Vad and All of you. Thank you very much
Problem solved replaced the GA Bord, everything fine now.
Afeef
freedom
Post by freedom »
Good to hear it's working now.
Locked
Return to “Media Gateway”
