Random Call Disconnection Problem in OXO
maaz
Post by maaz »
Dear Friends,
Thank you for cooperative responses. I am now facing another problem. I have 1 APA 8 trunk module in a live system. The issue is that the calls initiated by the trunks or landed on the trunks are being disconnected randomly. Sometimes the calls get disconnected after 2 minutes, sometimes after 6 minutes and sometimes it doesn't disconnect at all.
Please anticipate in finding out the solution.
Chamizo
Post by Chamizo »
Hello:
Try to uncheck the Busy Tone Detection on External lines/ List of accesses for aech trunk and test
Chamizo.
steve
Post by steve »
Hello Maaz,
You have to change the MinBusySeq from 3 to 5 in the Debug labels if you want to use the Busy Tone Detection.
MTConsulting
Post by MTConsulting »
put each trunk in a separate trunk group 460 = 1, 461 = 2, 462 = 3 etc, dial them one at a time and see which ones drop out, swap around to one that doesn't drop out and prove if it is the card or the carrier at fault.
enio.eltz
Post by enio.eltz »
Hi maaz
Only uncheck the busy tone detection at external lines --> list of access for each trunk. It will work.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
maaz
Post by maaz »
Thanks a lot... It worked...
MTConsulting
which advice did you use?
maaz
Post by maaz »
Just unchecked the busy tone detection....
Return to “Configuration”
