freedom wrote:
Why is the pbx not allowed to use your data backup link?
The signaling will only use about 9k6.
The voice itself (80-100K for one uncompressed call) can be routed using the public network.
But, in case of IP-Network failure there is no way to say to OXE: use only 9600 bps for signalling and do a private over public + use ars only on trunks that reside on this particular MG.
OXE is not a router, so it does not know about anything else on IP networking that default gateway.
When i've faced similar problem, i've got two solutions for bigger sites use PCS per MG, for smaller ones use router that (in case of network failure) could insert a rule to block any other network (CS, MG, INTIPs etc..) BUT not local IP for local 40x8 phones.
Config of DHCP for ALU ip-phones in backup mode is VERY hard thing to do it the right way.
