R.9.0 . ldap connectivity config
Hi all,
I am installing OXE R.9.0, i am facing issue with connectivity to ldap phone book..it's a external ldap conectivity..i don't know what to put it in LDAP config in OXE. please find below my config am i doing anything wrong..
Node Number (reserved) : 1
Instance (reserved) : 1
LDAP Phone book : 1
Server Name : hqdc ( server name . i can ping from oxe )
Server Port Number : 389 ( default port number )
User Identification : alcatel ( user name created in active directory )
Directory Root Entry : o=alcatel (this where i am stuck i don't wht to write down here )
User Password : ******
Confirm : ******
LDAP Phone book : 1
Confirm : ******
freedom
Hi all..
thanx for the reply..i used softerra to find my root it gave me the list and it's connected via softerra but from pabx still i can't get the names...plz find below my config...any other suggestion
LDAP Phone book : 2
Server Name : hqdc
Directory Root Entry : dc=ctcdom,dc=ctcgroupltd,dc=com
Confirm : ******
LDAP Phone book : 2
Server Name : hqdc
Confirm : ******
Have you done what freedom told you to do? If you have when you do a search if the name is found in the internal and also the LDAP you should get a phone book on your handset to do the extra search. You should also get an alarm within incvisu indicating that you have in facted connected to the ldap phone book if configured correctly
