SIP set back to H323 at OXO R7.10.052.007
MRFischer
Hi every one!
Well, I find my self in trouble with a R7.10.052.007
I just set the voice parameters to SIP protocol, and restart OXO.
But, when it get ready, it was back to H323 again...
I tried a few times. Same results...
Well, a checked the sw keys, ok
checked the CPU-4 and exchange for another, the same...
I tried the R7.10.22, the same...
I tried the old R6, and it works
I checked another client with CPU-4 and R7.10.18, and it is working...
Now, I'm tring thr R7.10.18 on this CPU-4.
Some one had the same situation?
Thanks and happy new year
I never had this problem with R7. Try this way: change to SIP and when the OMC shows the message to reset, press cancel and you must reset from system miscellaneous --> system reset. I always do this way and I have a lot of oxo with SIP/R7.
Best regards.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
MRFischer
MRFischer
Maurice
