We recently had a hard drive die in one of our switches (Node B). We replaced the hard drive and restored the database. However, since that time we have had issues dialing that switch.
We have 10 switches spread out over a wide area. Nine are on 5.0, One is on 6.1
Since the hard drive replacement, we see no problems at Node B. It can dial out to all of the other Nodes without a problem. However, all of the other nodes cannot dial into Node B on the IP trunks. Whenever you dial a 4 digit extension from the other nodes, you get a message stating, "You may request automatic callback by dialing 5" as if the extension(s) were busy.
We have tried resetting the hybrid links, re-enabling the x25 tunnell, and totally rebuilding the IP trunk groups on Node B & the Primary PCX. We have restarted the switch at Node B, and the Primary phone switch.
We are stumped. Additional information is all network connections seem fine, we can ping, telnet and traceroute the switch, and nothing looks wrong.
Any help will be greatly appreciated.
Cheers,
Joe
Network Node Unreachable through IP Trunk
alurfe
In ip parameters, there is a parameter called Inter node link signallinhg mode (i am not sure if it is the correct name) that must be equal in all the nodes. The mode can be h323 or not. Probaly on the resent node, it is not set to h323, witch was the default value or the only value possible (i do not remember)
Alcatel_exp
we had this problem before, and we found out that we can ping the CS from one node to the other, but from one node we cannot ping the remote GD's, it was the IP address configuration in the GD of the nodes(subnetmask). Check if you can ping th eremote CPU, GD/INTIP. Maybe after restoring the databse you didn't configure correctly the GD/INTIP IP Configuration.
I hope this will help you solve the problem. Many issues could be also the problem, like VPN Configuration.
