4XX8EE Phones with Asterisk
nguyennpsg
Re: 4XX8EE Phones with Asterisk
Hi Every one.
I have about hundred of 4008 IP Touch with the software version 3.71.70. With this version of firmware I can not find way to enable sip. If anyone has the newer firmware and know how to upgrade firmware for them then please help.
Thank you
Thank you
lhgomes
Hi All!!
We could upgrade several 4018 phones to connect to Asterisk and everything is working except that the devices do not emit the sound of the ring when someone calls the extension.
On the phone log, we have the following message:
000-00:06:15.560 AUDIO: wavMgt_readOpen: ring00.wav not found!
Has anyone experienced this?
irvan_tk
sori i'm newbie at ip touch, where i can download the firmware. i have ip touch 4018 to connect asterisk..
thank in advance
thank in advance
mouse click and back read this thread. you'll find and download the firmwares. just did a while ago.
voipsystems
Hi I have the same problem, it takes more minutes but is the same issue, any suggestion?
alex3385 wrote:Hi,
I've configured an 4018ee to use a sip account, the registration is ok but every 5 minutes the phone reboot.
I can se these lines in the log.
Anyone can help me?Code: Select all
<15>1 2012-01-16T20:19:35.378762+01:00 00 - - - 00:00:00 000-00:03:24.420 CH : CCEvent: Call Control Processing Event = CCEVT_STATUS ,reason = CCRSN_REG_OK ,cid = 80000001 <15>1 2012-01-16T20:19:35.379352+01:00 00 - - - 00:00:00 000-00:03:24.420 CH : CCEvent: Register Success <15>1 2012-01-16T20:19:35.380394+01:00 00 - - - 00:00:00 000-00:03:24.420 APP : app_timer_create | timer_id[8] <15>1 2012-01-16T20:19:35.381009+01:00 00 - - - 00:00:00 000-00:03:24.420 APP : app_timer_create | timer_id[9] <15>1 2012-01-16T20:19:35.381609+01:00 00 - - - 00:00:00 000-00:03:24.420 DISPLAY: ui_setprop(13):not created! <15>1 2012-01-16T20:19:35.382921+01:00 00 - - - 00:00:00 000-00:03:24.420 DISPLAY: ui_setprop(13):not created! <15>1 2012-01-16T20:19:35.383540+01:00 00 - - - 00:00:00 000-00:03:24.420 DISPLAY: ui_setprop(15):not created! <15>1 2012-01-16T20:19:35.384142+01:00 00 - - - 00:00:00 000-00:03:24.420 DISPLAY: ui_setprop(15):not created! <15>1 2012-01-16T20:19:35.384988+01:00 00 - - - 00:00:00 000-00:03:24.420 DISPLAY: ui_getprop(15):not created! <15>1 2012-01-16T20:19:35.385597+01:00 00 - - - 00:00:00 000-00:03:24.420 DISPLAY: ui_getprop(16):not created! <15>1 2012-01-16T20:19:35.386230+01:00 00 - - - 00:00:00 000-00:03:24.420 DISPLAY: ui_object_setprop(0x80d52010):no this property! <15>1 2012-01-16T20:19:35.386836+01:00 00 - - - 00:00:00 000-00:03:24.430 DISPLAY: ui_setprop(14):not created! <15>1 2012-01-16T20:19:35.388528+01:00 00 - - - 00:00:00 000-00:03:24.430 DISPLAY: ui_setprop(14):not created! <15>1 2012-01-16T20:19:35.389153+01:00 00 - - - 00:00:00 000-00:03:24.430 DISPLAY: ui_setprop(16):not created! <15>1 2012-01-16T20:19:35.390322+01:00 00 - - - 00:00:00 000-00:03:24.430 DISPLAY: ui_setprop(16):not created! <15>1 2012-01-16T20:19:35.390939+01:00 00 - - - 00:00:00 000-00:03:24.430 DISPLAY: ui_getprop(15):not created! <15>1 2012-01-16T20:19:35.391544+01:00 00 - - - 00:00:00 000-00:03:24.430 DISPLAY: ui_getprop(16):not created! <15>1 2012-01-16T20:19:35.392887+01:00 00 - - - 00:00:00 000-00:03:24.430 DISPLAY: ui_object_setprop(0x80d52010):no this property! <15>1 2012-01-16T20:21:35.573496+01:00 00 - - - 00:00:00 000-00:05:24.550 APP : app_timer_delete | timer_id[8] - Succeed <15>1 2012-01-16T20:21:35.573496+01:00 00 - - - 00:00:00 000-00:05:24.570 CH : ch_send_options_heart_beat:OPTION OK <15>1 2012-01-16T20:21:35.574015+01:00 00 - - - 00:00:00 000-00:05:24.570 APP : app_timer_delete | timer_id[9] - Succeed <15>1 2012-01-16T20:21:35.574015+01:00 00 - - - 00:00:00 000-00:05:24.610 CH : ch_send_options_heart_beat:OPTION OK <15>1 2012-01-16T20:22:07.698986+01:00 00 - - - 00:00:00 000-00:05:56.710 APP : app_call_set_sip_mode:set to standardmode and reset <15>1 2012-01-16T20:22:07.699623+01:00 00 - - - 00:00:00 000-00:05:56.710 DEFENCE: reset__: [112] sip_survi_to_sip_stand[H] (7780 app_call.c) <15>1 2012-01-16T20:22:07.700210+01:00 00 - - - 00:00:00 000-00:05:56.710 APP : app_timer_create | timer_id[8] <15>1 2012-01-16T20:22:07.701817+01:00 00 - - - 00:00:00 000-00:05:56.710 APP : app_call_set_sip_mode:set to standardmode and reset <15>1 2012-01-16T20:22:07.702470+01:00 00 - - - 00:00:00 000-00:05:56.720 DEFENCE: reset__: [112] sip_survi_to_sip_stand[H] (7780 app_call.c)
Thanks,
Alex
Did you manage the Forward to VM to work? Mine uses the same URI as the voicemail key. Any workaround?MM-P wrote:You´ll find in the attachment the latest firmware for the 4008 and 4018 phones.
Now MWI, Voicemail and missed calls are working.
DjCezzy
I am fairly new to the 4XX8 Phones, I have got one 4008 working with my asterisk pbx but I have 4028 and 4038 phones available.
I checked a 4028 and it is on firmware 3.7 with no sip compatibility.
From what I understand it needs to be at firmware 4.0 or higher to be sip compatible.
Can anyone share a 4.0 or higher firmware and tell me how to upgrade?
mrmhar81
which alcatel phones work as a SIP Phone, i succeeded to register 4018 phone as a SIP Phone but still i can't find a sip firmware for Alcatel 4086
jbr
Hello community,
I've got a Alcatel 4068 running in SIP mode. Although reading and testing multiple config files I haven't got a solution to get this phone completely up and running with my asterisk.
What I've done:
Setted up DHCP Server with all mandatory options and setted up TFTP server. The config files I used were provided by Renoud and andibiront. (Thanks so far guys for your great support, even if this thread is kind of old)
What do I need now? I've loaded up the config files sipconfig.txt and sipconfig-<mac-address>.txt to my tftp server. The phone boots, loads the ip-settings, provided by server and terminates in 3/5 with "Invalid Parameters", "gen conf file proc", like a member before.
Currently this is my sipconfig and sipconfig-<mac> file:
[basic]
[dns]
dns_addr=192.168.1.197
dns2_addr=192.168.1.196
hostname=alcatel_0080
[sip]
domain_name=pbx.lab.local
proxy_addr=pbx.lab.local
proxy_port=5060
local_sip_port=5060
sip_transport_mode=0
sip_transport_mode_survi=0
local_rtp_port=6000
local_rtcp_port=6001
preferred_vocoder=0,8,4,18
authentication_realm=201
authentication_name=201
authentication_password=zenT201
user_name=201
display_name=Phone 201
[telnet]
telnet_password=
[init]
application_mode=0
[audio]
tone_country=1
[appl]
admin_password=
Any suggestions? Can someone please provide firmware or else I need? Any help would be appreciated!!
Thank you all.
Jay
What I've done:
[basic]
[dns]
[sip]
proxy_port=5060
local_sip_port=5060
local_rtp_port=6000
user_name=201
[telnet]
telnet_password=
[init]
application_mode=0
[audio]
tone_country=1
[appl]
admin_password=
Thank you all.
Jay
pavel
Hi everyone,
I have a 4028EE switched to SIP fmwr and 2 questions regarding SIP fmwr.
1) I managed to feed it with datsip4028G and noesip4028G from some OXE 11.x release. Was it a correct way to switch so SIP fmwr ? BTW phone still complains during boot on lack of some files.
2) After telnet to phone an id command shows:
main 2.12.20 SIP
soft 4.32.70 NOE
*sipc 2.12.20 SIP
data 2.12.20 SIP
load 4.32.70
range SIP
type B
platform Gigabit
extended yes
I have an reREGISTRATION issue similar to one described here viewtopic.php?t=20760
Any chance someone with earlier/later fmwr can check whether it exists on their fmwr ?
Thanks.
Pavel.
main 2.12.20 SIP
soft 4.32.70 NOE
*sipc 2.12.20 SIP
data 2.12.20 SIP
load 4.32.70
range SIP
type B
platform Gigabit
extended yes
Thanks.
Pavel.
