4XX8EE Phones with Asterisk
faby
Re: 4XX8EE Phones with Asterisk
Post by faby »
hola a todos necesito registrar mi telefono 4018 en una central elastix ...alguien me podria ayududar
Reinoud
Post by Reinoud »
english please!
faby
Post by faby »
sorry:
I need to register phones Alcatel-Lucent IP Touch 4018 a telephone exchange elastix
sorry
if I can help with configuration files because the files I set out on the phone invalid parameter
Reinoud
Post by Reinoud »
If you share an example of your files here I can compare with mine to see if there are any parameters missing...
faby
Post by faby »
thanks ,but i already register ,had many parameters and just needed the basics
andibiront
Post by andibiront »
alex3385 wrote:Hi,
I've configured an 4018ee to use a sip account, the registration is ok but every 5 minutes the phone reboot.
I can se these lines in the log.
<15>1 2012-01-16T20:19:35.378762+01:00  00 - - - 00:00:00 000-00:03:24.420 CH     : CCEvent:  Call Control Processing Event = CCEVT_STATUS ,reason = CCRSN_REG_OK ,cid = 80000001
<15>1 2012-01-16T20:19:35.379352+01:00  00 - - - 00:00:00 000-00:03:24.420 CH     : CCEvent:  Register Success
<15>1 2012-01-16T20:19:35.380394+01:00  00 - - - 00:00:00 000-00:03:24.420 APP    : app_timer_create | timer_id[8]
<15>1 2012-01-16T20:19:35.381009+01:00  00 - - - 00:00:00 000-00:03:24.420 APP    : app_timer_create | timer_id[9]
<15>1 2012-01-16T20:19:35.381609+01:00  00 - - - 00:00:00 000-00:03:24.420 DISPLAY: ui_setprop(13):not created!
<15>1 2012-01-16T20:19:35.382921+01:00  00 - - - 00:00:00 000-00:03:24.420 DISPLAY: ui_setprop(13):not created!
<15>1 2012-01-16T20:19:35.383540+01:00  00 - - - 00:00:00 000-00:03:24.420 DISPLAY: ui_setprop(15):not created!
<15>1 2012-01-16T20:19:35.384142+01:00  00 - - - 00:00:00 000-00:03:24.420 DISPLAY: ui_setprop(15):not created!
<15>1 2012-01-16T20:19:35.384988+01:00  00 - - - 00:00:00 000-00:03:24.420 DISPLAY: ui_getprop(15):not created!
<15>1 2012-01-16T20:19:35.385597+01:00  00 - - - 00:00:00 000-00:03:24.420 DISPLAY: ui_getprop(16):not created!
<15>1 2012-01-16T20:19:35.386230+01:00  00 - - - 00:00:00 000-00:03:24.420 DISPLAY: ui_object_setprop(0x80d52010):no this property!
<15>1 2012-01-16T20:19:35.386836+01:00  00 - - - 00:00:00 000-00:03:24.430 DISPLAY: ui_setprop(14):not created!
<15>1 2012-01-16T20:19:35.388528+01:00  00 - - - 00:00:00 000-00:03:24.430 DISPLAY: ui_setprop(14):not created!
<15>1 2012-01-16T20:19:35.389153+01:00  00 - - - 00:00:00 000-00:03:24.430 DISPLAY: ui_setprop(16):not created!
<15>1 2012-01-16T20:19:35.390322+01:00  00 - - - 00:00:00 000-00:03:24.430 DISPLAY: ui_setprop(16):not created!
<15>1 2012-01-16T20:19:35.390939+01:00  00 - - - 00:00:00 000-00:03:24.430 DISPLAY: ui_getprop(15):not created!
<15>1 2012-01-16T20:19:35.391544+01:00  00 - - - 00:00:00 000-00:03:24.430 DISPLAY: ui_getprop(16):not created!
<15>1 2012-01-16T20:19:35.392887+01:00  00 - - - 00:00:00 000-00:03:24.430 DISPLAY: ui_object_setprop(0x80d52010):no this property!
<15>1 2012-01-16T20:21:35.573496+01:00  00 - - - 00:00:00 000-00:05:24.550 APP    : app_timer_delete | timer_id[8]  - Succeed
<15>1 2012-01-16T20:21:35.573496+01:00  00 - - - 00:00:00 000-00:05:24.570 CH     : ch_send_options_heart_beat:OPTION OK
<15>1 2012-01-16T20:21:35.574015+01:00  00 - - - 00:00:00 000-00:05:24.570 APP    : app_timer_delete | timer_id[9]  - Succeed
<15>1 2012-01-16T20:21:35.574015+01:00  00 - - - 00:00:00 000-00:05:24.610 CH     : ch_send_options_heart_beat:OPTION OK
<15>1 2012-01-16T20:22:07.698986+01:00  00 - - - 00:00:00 000-00:05:56.710 APP    : app_call_set_sip_mode:set to standardmode and reset
<15>1 2012-01-16T20:22:07.699623+01:00  00 - - - 00:00:00 000-00:05:56.710 DEFENCE: reset__: [112] sip_survi_to_sip_stand[H] (7780 app_call.c)
<15>1 2012-01-16T20:22:07.700210+01:00  00 - - - 00:00:00 000-00:05:56.710 APP    : app_timer_create | timer_id[8]
<15>1 2012-01-16T20:22:07.701817+01:00  00 - - - 00:00:00 000-00:05:56.710 APP    : app_call_set_sip_mode:set to standardmode and reset
<15>1 2012-01-16T20:22:07.702470+01:00  00 - - - 00:00:00 000-00:05:56.720 DEFENCE: reset__: [112] sip_survi_to_sip_stand[H] (7780 app_call.c)
Anyone can help me?
Thanks,
Alex
I'm having this problem also. The phone works fine (4018EE), for about 15 to 20 minutes. When I telnet to the phone, there are no errors, only a heartbeat once in a while. After 20 minutes, the phone disconnects, and the diplay say "Not registered". If I telnet again I can see:
000-03:33:52.040 DISPLAY: ui_object_setprop(0x80d7a050):no this property!
000-03:33:52.050 DISPLAY: ui_setprop(14):not created!
000-03:33:52.050 DISPLAY: ui_setprop(16):not created!
000-03:33:52.050 DISPLAY: ui_getprop(15):not created!
000-03:33:52.050 DISPLAY: ui_getprop(16):not created!
If I reboot the phone, everything works fine again for 20 minutes or so.
Any ideas??
Thanks!
PD:
I'm using AsteriskNOW 11, BTW.
Reinoud
Post by Reinoud »
it looks like Alex' phone is switching from SIP survivability mode to normal mode... maybe wrong config file? Doy you have the same lines Andi?
andibiront
My sipconfig is pretty simple. I don't know much about this, so I copied a SIP config file from here and edited it.
This are the values:
[basic]
[dns]
dns_addr=192.168.10.1
dns2_addr=192.168.10.241
hostname=192.168.10.50
[sip]
domain_name=192.168.10.107
proxy_addr=192.168.10.107
proxy_port=5060
local_sip_port=5060
sip_transport_mode=0
sip_transport_mode_survi=0
local_rtp_port=6000
local_rtcp_port=6001
preferred_vocoder=0,8,4,18
authentication_realm=living
authentication_name=living
authentication_password=
user_name=living
display_name=Living
[telnet]
telnet_password=
[init]
application_mode=0
[audio]
tone_country=4
[appl]
admin_password=
[admin]
disable_pc_port=0
activate_vlan_filter=0
juniorloureiro
Post by juniorloureiro »
Hello all.
I'm new here and I'm having some troubles with my Alcatel Lucent 4018
I never used asterisk or IP Phones.
I'm trying to use reynoulds config file on HTTP server, cause I dont know how to config tftp server.
My phone try to downloads the config file, (he actually download) and then says "file not found" then "Reset... please wait".
Any tips so I can get more information on how to fix it?
davide_patriarca
Post by davide_patriarca »
Hello everyone, I have a strange problem with 4018EE phones registered on a Huawei U2980 PBX... What happens is that I'm able to register them on the system and calls between a 4018 and other phones (I have some Cisco and Huawei phones connected to the same PBX) are working fine. The problem shows when I try to call between 2 4018: the quality is really crappy and the wireshark trace shows lots of ICMP Destination Unreachable packets between the two phones. With the other phones the RTP flow is clean and the call quality is pretty good...
Any advice?
Thanks in advance!
Davide
Return to “Asterisk”
