Error coming when creating the External numbering Plan....
shahin
Re: Error coming when creating the External numbering Plan..
Hello ,
Can you please tell me that what is meant by range , because i think i added wrong range number....for Some extension i added 1 ,19,3, like that....
Range is that, a range of numbers. For example if you put initial number = 1 and a range of 4 will be like saying 1,2,3,4.
shahin
Hello ,
Please find the DID translator below ,
Default DID num. translator
Node Translator External Numbering Plan First External Number First Internal Number Range Size Unique Internal Number
governer 1 1 444 444 1 NO
governer 1 1 511 511 4 NO
governer 1 1 515 515 1 NO
governer 1 1 516 1516 19 NO
governer 1 1 535 535 1 NO
governer 1 1 536 536 1 NO
governer 1 1 538 538 1 NO
governer 1 1 539 539 1 NO
governer 1 1 541 541 1 NO
governer 1 1 547 547 1 NO
governer 1 1 550 550 1 NO
governer 1 1 555 A000 1 NO
governer 1 1 556 556 2 NO
governer 1 1 558 558 1 NO
governer 1 1 560 560 1 NO
governer 1 1 561 561 1 NO
governer 1 1 565 565 1 NO
governer 1 1 566 1566 1 NO
seems ok
but note 523 is included under 516 range 19
shahin
Hello ,
But when i creating DID for 523 with 19 is coming the error...
note when you create ext 516 intern 1516 range 19 , even you don't seen them but automaticlly you have alsocreate those external numbers from 517 to 534 ; and u created auytomaticlly the corespendent internal numbers from 1517 to 1534
so normal that you got this error becuase ext 523 is included [516 534]
in your case you can not mixe suchus
you have to create external from 516 , internal1516 range 5 (so from 522all other sould be excluded)
you have to create external 523 internal 523 range 19, if you select this range(19 number) so from 523 to 541 all those numbers 'still exiting should be removed before especially those
imagine in the actual situation and pbx has accept you config 516,1516,19 and 523,523,19 for same operator when an incoming call ask for 520 ,the pbx willbe in hell to where route this call to 1520 or to 520!!
shahin
Hello ,
Thank a lot, Yes its working....
But now when i creating 530,536,541 with range 19 is coming same error....
here a sample how should be you config as you see 523 is accepted,note i dont put the whole config
again same error lol
when you have 523,523,19 in did , so 524,525,526 ..........530...536...541 are automaticlly created
