just check:
http://slimphony.blogspot.com/
This was the main root of all our efforts when did the OXE VMWare possible...
how to install OXE on VMWare
- cavagnaro
Re: how to install OXE on VMWare
I installed i1605.0 in my VMWARE. But when i try to do a patch upgrade it gives me the following error:
cat: write error: No space left on device
Can anyone suggest if they faced such a problem
- Konstantinos.E
hi
increase the capacity of your virtual hard disk.
run df -v and see what useage you have.
Alca_holic
its showing me hda9 is 100% is full... How do I increase... my hard disk space is 8GB
- Konstantinos.E
You have to read the technical comunication about the release you want to install.but the most of the releases wants at least 40G.
When you create a new virtual machine it ask you for the capasity of the hard disk.
Alca_holic
Thanks Konstantinos... I made the virtual hard disk 50 GB and its working fine...
- Konstantinos.E
If you search this forum all of your questions will be answered .this topic has been discussed countless times.
Alca_holic
