OMS Compressors
Re: OMS Compressors
cs role address in oms config is missing.
regards...
regards...
- tot3nkopf
Re: OMS Compressors
MAC address configured in OMS shelf -->GD3 ?, Shelf declared as OMS? We are not psychics...
Do you even care to read the installation/configuration docs?.....
Re: OMS Compressors
i agree to tot... you have to read more carefully the docs...
also give more information.
which ip-address has your callserver?
do you have some incidents?
please seand the output of command:
regards...
cat /usr3/mao/lanpbx.cfg
Re: OMS Compressors
Dear TOT/Tgn
you are absolutely right. i am following the documents.
yeah sure i will post some more details info about this...
Re: OMS Compressors
delete OMS shelf and recreate it..put the mac address...it should be active if u put a correct mac....
Re: OMS Compressors
HI TOT/Tgntgn wrote: ↑07 Apr 2017 07:21 i agree to tot... you have to read more carefully the docs...
please seand the output of command:regards...Code: Select all
i deleted the OMS shelf , reconfigured , put the MAC and it is in service now....
Thanks for you all for bearing all my questions.... and thanks for being so patience.
now if i created one ip extension. its NOT getting the tftp server
on ip phone 8028 i put static ip 10.1.1.80/24 gate way is my CS vm (10.1.1.1) and tftp server is my active cs ip (10.1.1.3). i have licensing for ip.
i also declared 120 voip resources in gd3 board. the set is is showing no response from tftp server.
Re: OMS Compressors
congratulations on your success with oms!
but a non working ip-phone is a different topic.
do not mixing topics and open a new thread (as cav said).
regards...
regards...
Re: OMS Compressors
Hi Tgn
Its working ,,, was a vlan issue.
Re: OMS Compressors
hi there, was you able to get the OMS (virtual GD) running?
