OXE lost configutarion
Re: OXE lost configutarion
in the kernel line parameters list...
follow the posted link... 3rd screenshot...
regards...
--- back to basics... focus your eyes on the essential things... ---
regards...
Does someone know if this procedure works for new releases?? (>12.0)
I am getting this error from this command...
grub> kernel /boot/vmlinuz root=/dev/hda5 console=ttyS0,9600 panic=5 single
Error 15: File not found
after some research I see that partitions change... I translate it to this:
root (hd0,1)
kernel /boot/vmlinuz root=/dev/sda2 console=ttyS0,9600 panic=5 single
boot
However I get load with this prompt:
kdb>
and I see this message:
VFS: Cannot open root device "sda2" or unknown-block(0,0)
Please append a correct "root=" boot option; here are the available partitions:
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
Pid: 1, comm: swapper Not tainted 2.6.32-ll-dhs3 #1
Any help???
root (hd0,1)
boot
kdb>
Any help???
Looks like general HD problem or MBR.
If you have DB saved reinstall the Release and load DB.
mmm... but everything works just fine with the HD.
Do you have applied this procedure to an OXE in a new release??
Yep, installed it on CPU8 without any problem.
If you sure about yuor HD then it's grub problem so try to play with grub command line.
