INT-IP2 card not work
alex
Post by alex »
Vow! The best of the best of this board are here!;)
Let me add my two cents:
- "lanpbxbuild" MUST BE run whatever you have experienced without having lanpbx.cfg created.
- "lanpbxbuild -auto" is not recommended any more since R7. Run "lanpbxbuild" in menu mode.
- as Frank said the problem sure is in tftp error so check IP/IP parameters/Ethernet Address Checked By TFTP=False and run "actdbg tftpd=on; traced" trace.
victornew
Post by victornew »
Hi doublevand981,
Sorry for the wrong input..
:confused:
IP/IP parameters/Ethernet Address Checked By TFTP - intresting for INTIPB, GD. For INTIPA, GA - maybe true, maybe false.
doublevand981 wrote:hi all,
below is results:
(1)viscohn> lanpbxbuild -auto
wed jun 30 12:59:26 cest 2010
ip cpu 1: 192.168.1.100
are you sure (y/n):y
permission denied.
Permission denied.
(1)viscohn> cdmao
/dhs3data/mao
(1)viscohn> more lanpbx.cfg
lanpbx.cfg: No such file or directory
(1)viscohn> more /usr4/mao/lanpbx.cfg
/usr4/mao/lanpbx.cfg: No such file or directory
(1)viscohn>
read the error messages!
If you can't create this file, none of your IP boards / IP Phones are going to boot.
Don't look further, this is where you issue is.
doublevand981
Post by doublevand981 »
Dear all,
i checked by "chkconfig --list" command and results that no tftp service running.
pls show me the way to add and activate this service.
thanks and best regards
Dude,
This has nothing to do with the tftp server running.
YOU GET A PERMISSION DENIED WHEN YOU TRY TO CREATE A LANPBX FILE !
FIX THIS !
doublevand981
hi Frank,
can you show me how to fix this?
thanks
cdmao
ls -la
whoami
doublevand981
Dear Frank
i done these command and got long results that can not post here. pls see attached file for information and help me to fix it.
thanks
cdmao
touch lanpbx.cfg.old
lanpbxbuild -auto
Return to “IP”
