connecting elastix (freebpx based, witch is based on asterisk) to omnipcx enterprise
sylpid
Re: connecting elastix (freebpx based, witch is based on ast
Post by sylpid »
Thanks, everything is running well now :)
am1
Re: connecting elastix (freebpx based, witch is based on asterisk) to omnipcx enterprise
Post by am1 »
Hi, I am quite noob with OXE so please bear with me if some of these question sound silly.
I am trying to connect Elastix to OXE via a SIP trunk.
I managed to get calls made from Elastix to pass via the SIP trunk by setting up the trunk and outbound rules on the Elastix side.
What remains unclear is how I can send incoming calls from OXE to Elastix via the SIP trunk.
Should I setup an exernal gateway?
Also which DiD and Trunk Main No should I use for inbound rules on the Elastix side? Which format? I thought I should use the three digit notation, but it requires at least 4.
Can someone guide me step by step how can i get calls to xxxxxxxx110 OXE go to say xxxxxx543 on the Elastix side?
Thanks in advance.
I think the best idea - to ask this questions on Elastix forum...
am1
Post by am1 »
I have no problem with Elastix config. That part is straightfoward and works fine. It's the Alcatel trunk/translator part I need help with.
am1
Post by am1 »
How do I add the tag/DID to the sip header?
It only says To: <sip:110@10.10.1.24;user=phone>
Do you have system documentation for OXE?
In System doc/ IP-PCX networks/ SIP/ SIP trunking - exist description and management examples.
am1
Post by am1 »
I inherited the system and I do not have the doc.
Can you please guide me to add this information to the sip header? I just need the DDI info to be present in the "To" part so I can do the routing on the other side. Everything else works.
I tried all parameters in the sip external gateway section but nothing.
I am confused about what to do.
Here is the config:
Trunk Group
lqConsult/Modify: Trunk Groupsqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Trunk Group Id : 11 x
x x
x Trunk Group Type + T2 x
x Trunk Group Name : Elastix x
x UTF-8 Trunk Group Name : ------------------------------------------- x
x Number Compatible With : -1 x
x Remote Network : 14 x
x Shared Trunk Group + False x
x Special Services + Nothing x
x Node number : 1 x
x Transcom Trunk Group + False x
x Auto.reserv.by Attendant + False x
x Overflow trunk group No. : -1 x
x Tone on seizure + False x
x Private Trunk Group + False x
x Q931 signal variant + ABC-F x
x SS7 signal variant + No variant x
x Number Of Digits To Send : 3 x
x Channel selection type + Quantum x
x auto.DTMF dialing on outgoing call + NO x
x T2 Specificity + SIP x
x Homogenous network for direct RTP + NO x
x Public Network Category : 31 x
x DDI transcoding + True x
x Can support UUS in SETUP + True x
x x
x Implicit Priority x
x x
x Activation mode : 0 x
x Priority Level : 0 x
x x
x Preempter + NO x
x Incoming calls Restriction categ. : 10 x
x Outgoing calls Restriction categ. : 10 x
x mpt1343 callee number + NO x
x Overlap dialing + YES x
x Call diversion in ISDN + NO x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
NPD Selector
lqConsult/Modify: Trunk Group NPD Selectorqqqqqqqqqqqk
x x
x Instance (reserved) : 1 x
x x
x Public NPD id : 3 x
x Private NPD id : 0 x
x Management Mode + Automatic x
x Public DDI transcoding + True x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
lqConsult/Modify: Numbering Plan Description (NPD)qqqqqqqqqqqqqqqqqqqqqk
x x
x Description identifier : 3 x
x x
x Name : U_U_E_E_DDI x
x Calling Numbering plan ident. + Unknown x
x Called numbering plan ident. + Unknown x
x Authorize personal calling num use + False x
x Install. number source + Entity source x
x Default number source + Entity source x
x Called DID identifier : 0 x
x Calling/Connected DID identifier : 0 x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
x x
x Description identifier : 0 x
x x
x Name : U_U_N_N_NDDI x
x Install. number source + None used x
x Default number source + None used x
x Called DID identifier : -1 x
x Calling/Connected DID identifier : -1 x
x x
lqConsult/Modify: DDI Numbering Translatorqqqqqqqqqqqqqqqqqqqk
x x
x DDI num. transl. identifier : 0 x
x x
x Name : LIMITED_LOCAL_DID x
x DDI translator Mode + Default Mode DDI x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
lqConsult/Modify: Default DDI Num. Translatorqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x First External Number : 100 x
x x
x First Internal Number : 100 x
x Range Size : 100 x
x Unique Internal Number + NO x
x x
lqConsult/Modify: Numbering Planqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Number : 110 x
x x
x Prefix Meaning + Network No. x
x Identifier of Domain : 0 x
x Network Number : 14 x
x Node Number/ABC-F Trunk Group : 11 x
x Number With Sub Address (ISDN) + NO x
x Type + Station x
x Identifier : 0 x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
lqConsult/Modify: Network Routing Tableqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x x
x Rank of First Digit to be Sent : 1 x
x Incoming identification prefix : -------- x
x Protocol Type + ABC_F x
x Numbering Plan Descriptor Id : 11 x
x ARS Route list : 0 x
x Schedule number : -1 x
x ATM Address Id : -1 x
x Network call prefix : -------- x
x Town Name : -------------------- x
x Send Town Name + False x
x Associated SIP gateway : 0 x
x Unable_UTF8 + True x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
x x
x Description identifier : 11 x
x x
x Name : U_U_P_P_NDDI x
x Install. number source + NPD source x
x Default number source + NPD source x
x Installation number : ------------------------------ x
x Default number( num. inst. sup.) : ------------------------------ x
x x
Thanks in advance for the help!
Q931 signal variant - I think better to use "ISDN for all countries"
Used NPD 3, DID 0 with rules 100-100-100
So, according DID 0 rules when user 1XX make call caller ID will be 1XX.
If you what caller id 1234561XX for user 1XX - in DID rules manage 123456100 (external number)-100(corresponded internal number)-100(range size) (123456101=101, ..123456199=199)
am1
Post by am1 »
I cannot select and change the Q931 signal variant for some reason...
It goes from Private Trunk Group to SS7 signal variant skipping the line in the middle.
Am I doing something wrong?
Edit: Even if I change the DID when I outbound dial to 110 and the call from OXE reaches the other side of the trunk, I cannot see any "Destination Number" DID in the sip header on the other side.
It just says To: <sip:110@10.10.1.24;user=phone>
How can I fix this?
can post sip external Gateway and some call traces
Return to “Asterisk”
