In BOARDS check, for example
│ Interface Type + GD
│ IP Compression Daughter Board + MCV24
│ Nb of Compressors for Gateway : 5
│ Nb of Compressors for IP Devices : 16
ih the GD on your MG and the MG 18.
How to Load Voice Mail
afeef
Thank you Vad
appreciate if you could see below details? your comment is highly appreciated.
config all
Wed Apr 14 09:51:44 CEST 2010
Cristal 0 :
| 0 | 6 | CPU_CS|---------- | IN SERVICE | NO PCMS CODE |
| 0 | 10 | CPU_CS|---------- | REG NOT INIT | NO PCMS CODE |
> Reference rack not set
Cristal 1 :
| 1 | 0 | GD|---------- | IN SERVICE | BAD PCMS CODE |
| 1 | 1 | SLI 16(Z)|---------- | IN SERVICE | BAD PCMS CODE |
| 1 | 2 | PRA T2|---------- |ONLY OPS FILE | BAD PCMS CODE |
| 1 | 3 | SLI 8 (Z)|---------- |ONLY OPS FILE | BAD PCMS CODE |
| 1 | 4 | BRA 2|---------- |ONLY OPS FILE | BAD PCMS CODE |
| 1 | 8 | CS|---------- | CS+4645 | BAD PCMS CODE |
--- Inter Crystal Topology ---
| CR | CPL Type Role Free/Tot Role Type CPL | CR |
|001 | 00 -GD (MAIN ) --- 16/16 --- ( INT_A) INTIPA - 01 |019 |
Cristal 18 :
| 18 | 0 | GD|---------- | IN SERVICE | NO PCMS CODE |
| 18 | 1 | 4645|---------- | IN SERVICE | NO PCMS CODE |
|018 | 00 -GD (MAIN ) --- 24/24 --- ( INT_A) INTIPA - 01 |019 |
Cristal 19 :
| 19 | 0 | FICTIF| | REG NOT INIT | NO PCMS CODE |
| 19 | 1 | INTIPA| | IN SERVICE | NO PCMS CODE |
| 19 | 2 | INTIPA| | OUT OF SERV | NO PCMS CODE |
| 19 | 3 | Z_FICTIF| | IN SERVICE | NO PCMS CODE |
|019 | 01 -INTIPA (INT_A ) === 16/16 === ( MAIN) GD - 00 |001 |
|019 | 01 -INTIPA (INT_A ) === 24/24 === ( MAIN) GD - 00 |018 |
compvisu lio
Wed Apr 14 09:52:23 CEST 2010
wait...
| C O M P V I S U L I O |
| cr | cp | type dsp | coupler state | H323 Gateway |
| | | | | for direct RTP |
| | | | | free/max |
| 1 | 0 | GD MADA3* | IN SERVICE | 0/16 |
| 18 | 0 | GD MADA3 | IN SERVICE | 16/24 |
| 19 | 1 | INTIPA 1GIP6* | IN SERVICE | 0/0 |
| 19 | 2 | INTIPA 1GIP6* | OUT OF SERVICE | 0/0 |
| '*' mean : transit is not provided on this board. |
config 1 - 0 -d
Wed Apr 14 09:53:51 CEST 2010
| Cr | cpl| Hardware type | cpl state | coupler ID |
| 1 | 0 | GD | IN SERVICE | BAD PCMS CODE | *
| 1 | 0 | NO_SUB_BOARD | IN SERVICE | NO PCMS CODE | *
Afeef
config all
Cristal 0 :
Cristal 1 :
Cristal 18 :
Cristal 19 :
compvisu lio
wait...
| | | | | for direct RTP |
| | | | | free/max |
config 1 - 0 -d
Afeef
As I understand - you find problem.
| 1 | 0 | GD MADA3* | IN SERVICE | 0/16 | - you have no free codecs for VM, must be like 16/16, 15/16...
| 1 | 0 | NO_SUB_BOARD | IN SERVICE | NO PCMS CODE | * you have no MADA, must be MADA1 (or MADA3) - you have NO_SUB_BOARD
afeef
