OXE VMware appliance
I have mine working fine, Piped TCP for Serial port is mandatory, otherwise installation can't be done.
What is weird for me is that a previous installation stopped working on it's piped. Had to reinstall all again, weird.
avk
Post by avk »
cavagnaro wrote:I have mine working fine, Piped TCP for Serial port is mandatory, otherwise installation can't be done.
Installation can be done without Piped TCP for Serial if you choose 'Blade Server' instead of 'Appliance Server' in PC Installer. In that case kernel console isn't redirected to serial port.
You can use a physical COM port of your computer, too, if you don't want to use a piped one :D . But what's the point? :roll:
tadaxi
Post by tadaxi »
success in R 7.1
OK!!!!
Pc installer choose blade server
can not choose alize/a4400/appliance server
finaluser
Post by finaluser »
Another solution for Serial Port use is to direct to a Pipe with server side on the OXE emulation and as a client in another Virtual machine with another OS , like Linux with Minicom or Windous with HyperTerminal
finaluser
finaluser
Re: OXE VMware appliance
Post by finaluser »
I just install Release 8.0 on Vmware, all is working fine.
For Serial I'm currently using Named Pipe TCP Proxy.
finaluser
For R8 seems you don't have to do the hack of mac address anymore. I did my install and everything went smooth.
luckyme2
Post by luckyme2 »
finaluser wrote:I just install Release 8.0 on Vmware, all is working fine.
R8 can be installed as blade server and NPTP is not necessary anymore (at least during install)
lm2
poposami
Post by poposami »
I have OXE R8.0 vm disk,tried to open on another pc.But not able see anything on hyperterminal.I am using named pipe with default port 567 and com_3.When i open serial port com3,hyperterminal show nothing.Vertiual machine is powered up.What setting should i use on the hyperterminal and for named pipe?
bouncer_ie
Post by bouncer_ie »
Hi All trying to install 8.01 g1.503 and I keep getting the attached when installing not sure if related to ethernet issue but tried the fix on slimphony and i get a message stating my MAC address is not valid ...any ideas?
Return to “Other”
