Dialer 2.0
BertrandB21
Kind of Dialer
Hi i'm working on a web application and i need to call customers. All my operators have IP_Touch phones. May i use the dialer ? how to dialog beetwen web appli and dialer ?
Some of my operators have AASTRA phones and it's possible to launch a dial sending an xml POST on the phone. Iptouch have the same function ?
- tot3nkopf
Re: Dialer 2.0
No. Just use web services for this purpose --> you need UC licenses (for presentation server --> bundled in the latest UC releases in My IC user license).
Jimmyboyle
Re: Dialer 2.0
Hi Frank,
is it possible to get teh source code for Dialer 2.0 ?
thanks
thanks
mothinx
Re: Dialer 2.0
Hi ! I have the version 1.3 of dialer in a system. What is the process to install the new version ? I need the immediate FW feature !
Thanks a lot !
(101)XXXXXXXX> ./dialer
DIALER - Made by Frank Gadot - frank@alcatelunleashed.com
VERSION 1.3 - 2007.07.19
USAGE: dialer Neqt_number [number_to_call OR option]
Option are:
-> onhook To simulate a onhook
-> offhook To simulate a offhook
-> handsfree To simulate the speakerkey being pushed
-> interphone To simulate a push on the MUTE key,
in order to (de)activate auto-answer
-> lifthandset To simulate the handset being lifted
(so you won't hear the speakerphone)
-> apt Simulate an appointment , and make the phone ring
Please visit http://www.AlcatelUnleashed.com !
Thanks a lot !
Option are:
Tan Phu
Re: RE: Re: Dialer 2.0
letacla wrote:Hi,
I have the same problem: DIALER not working on rel.9.1
Is there any chance for an update?Mr. Frank Gadot
thx
Sent from my SM-A500H using Tapatalk
- frank
Re: Dialer 2.0
Hi ,
To update you simply need to install the 2.0 on your CPU. Nothing else to do.
What is the error message on 9.1 ?
Tan Phu
Re: Dialer 2.0
Hi Frank!
Thanks for your reply!
My problem is I only can dial on the digital and IP phone. I need to test with the analog phone but it seems not working? Do i need to modify some things else in the OXE system?
Thanks and regards!
Phu
Thanks and regards!
Phu
