OXE PC Installer startup
aalmanzar
Pc installer
Post by aalmanzar »
I cannot even installed any of the releases, I tried several times and nothing happens. Any ideas???
Send screen shots.
You probably have some virtual interfaces that are screwing up everything.
You probably use Windows 7 ..?
aalmanzar
Post by aalmanzar »
Funny thing,
this was not working on window XP,
I loaded the Window 7 and now it is now working. I allow it to be install and now it is working fine.
it was probably my PC anyway, I had lot's of issues with it!
thanks for the help,
ambi
Return to “Software Loading”
