4XX8EE Phones with Asterisk
carlocarlo
Re: 4XX8EE Phones with Asterisk
Post by carlocarlo »
sorry, I did not understand what am I wrong?
all of my sip phone are configured by provisioning tftp(option 66) server, why the alcatel not do this?
There are specific codes like Alcatel vendor ID to be included.
Please read basic DHCP server doc and later you can test
carlocarlo
i search on forum and follow this guide:
8AL90824AAAAed01-IPTouchSIPphonesinstallation.pdf
Now, telnet mode command "dwl" show the mode SIP.
When the phone boot search the configuration, see in tcpdump:
192.168.199.205.blackjack > 192.168.199.xxx.https: Flags [F.], cksum 0xe580 (correct), seq 861, ack 1567, win 17376, options [nop,nop,TS val 3613 ecr 3197506319], length 0
IP (tos 0x0, ttl 64, id 5484, offset 0, flags [DF], proto TCP (6), length 52)
192.168.199.xxx.https > 192.168.199.205.blackjack: Flags [.], cksum 0x28d9 (correct), seq 1567, ack 862, win 130, options [nop,nop,TS val 3197506326 ecr 3612], length 0
ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.199.xxx tell 192.168.199.205, length 46
ARP, Ethernet (len 6), IPv4 (len 4), Reply 192.168.199.xxx is-at 00:50:56:a2:2f:fb, length 28
IP (tos 0x0, ttl 64, id 19, offset 0, flags [none], proto UDP (17), length 73)
192.168.199.205.1024 > 192.168.199.xxx.domain: [udp sum ok] 1+ A? {{ NTP_SERVER }}.xx.xx.xx. (45)
IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto UDP (17), length 125)
192.168.199.xxx.domain > 192.168.199.205.1024: [bad udp cksum 73af!] 1 NXDomain q: A? {{ NTP_SERVER }}.xx.xx.xx. 0/1/0 ns: xx.xx.xx. [49m26s] SOA dns1.xx.xx.xx. postmaster.xx.xx.xx. 2018101501 10800 3600 604800 3600 (97)
IP (tos 0x0, ttl 64, id 20, offset 0, flags [none], proto UDP (17), length 62)
192.168.199.205.blackjack > 192.168.199.xxx.domain: [udp sum ok] 2+ A? {{ NTP_SERVER }}. (34)
IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto UDP (17), length 137)
192.168.199.xxx.domain > 192.168.199.205.blackjack: [bad udp cksum f31f!] 2 NXDomain q: A? {{ NTP_SERVER }}. 0/1/0 ns: . [2h49m27s] SOA a.root-servers.net. nstld.verisign-grs.com. 2018101600 1800 900 604800 86400 (109)
IP (tos 0x0, ttl 64, id 21, offset 0, flags [none], proto UDP (17), length 73)
192.168.199.205.cap > 192.168.199.xxx.domain: [udp sum ok] 3+ A? {{ NTP_SERVER }}.xx.xx.xx. (45)
192.168.199.xxx.domain > 192.168.199.205.cap: [bad udp cksum 7054!] 3 NXDomain q: A? {{ NTP_SERVER }}.xx.xx.xx. 0/1/0 ns: xx.xx.xxt. [46m41s] SOA dns1.xx.xx.xx. postmaster.xx.xx.xx. 2018101501 10800 3600 604800 3600 (97)
IP (tos 0x0, ttl 64, id 22, offset 0, flags [none], proto UDP (17), length 62)
192.168.199.205.1027 > 192.168.199.xxx.domain: [udp sum ok] 4+ A? {{ NTP_SERVER }}. (34)
192.168.199.xxx.domain > 192.168.199.205.1027: [bad udp cksum f06d!] 4 NXDomain q: A? {{ NTP_SERVER }}. 0/1/0 ns: . [2h43m53s] SOA a.root-servers.net. nstld.verisign-grs.com. 2018101600 1800 900 604800 86400 (109)
but not find my files "sipconfig-00809ff8fa46.txt" and "sipconfig.txt" on tftp. What i wrong?
infoso
Post by infoso »
Hello, I have an Alcatel Lucent 8038.
I can not change the device from NOE to SIP mode. It just does not save the change.
can someone help me? Thx
infoso wrote:Hello, I have an Alcatel Lucent 8038.
Check your firmware version, is not the last one
And doesn't allow it. Or your set type is not supported. Not all 40x8 can go sip, only some editions.
infoso
Post by infoso »
cavagnaro wrote: 16 Oct 2018 10:04
Hello, the Firmware Version is NOE 4.52.13. Is the firmware SIP Compatibel?
THX
carlocarlo
I managed to manage the phone with an asterisk, the only problem is that it doesn't display the missed calls.
Can anyone help me? in the features of the phone there isn't.
Thank's
Lovert
Post by Lovert »
hello distinguished gurus;
I have 15 iptouch 4068EE phones and an installed and working asterisk server. I read from this thread that it is possible to make 4008 and 4018 work with the asterisk sip server by obtaining and loading the sipconfig.text file to the tftp server in your network where the phones have to download their configurations at boot time. I have two questions
1) Does the above process still apply to my iptouch 4068EE phones; if yes am i oblige to use the same sipconfig.txt and/or sipconfig-macaddress.txfile sited above??
2) can someone help me with a detailed step by step procedure on how to setup and upload the config files to my tftp server??
Thanks very much in advance
kennyhuang
Post by kennyhuang »
Hi all,
I'm looking for a compatible version of the noesip8038N binary file for datsip8038N (version 3.00.50).
Thanks in advance.
dmarjolin
Post by dmarjolin »
I've just replaced my Alcatel PABX with a SIP one and trying to get my 4018EE, 4028EE & one 4038EE sets to work in SIP mode.
I've put my sipconfig.txt, sipconfig-MACADDR.txt as well as the 4018 & 4028 bin files in the tftp root folder of the PABX and the phones work +/- well. The only things are that:
1. I get a "file not found" after the "Updating Load" step (is the absence of the lanpbx.cfg in the tftproot folder the cause?), and
2. I can't search by extension name on the phones. I can only do so on the local phone directory.
3. The "programmable" keys don't work.
Grateful if someone could assist.
Return to “Asterisk”
