4XX8EE Phones with Asterisk
Re: 4XX8EE Phones with Asterisk
So... What do you need help at exactly?
carlocarlo
Post by carlocarlo »
Hi everybody,
these posts were very thin.
I'm in this situation, i have the phone in noe mode and i can put it in industry mode for launch via telnet "appl mode SIP"(after press 123i button), then it start to search this binary files:
noesip8038N
https://ufile.io/dl6gj
datsip8038N
datsip80X8N.zip
Then I should put on Asterisk tftp the file(see the attachments - language italian):
sipconfig.txt
sipconfig.txt
sipconfig-mac.txt
sipconfig-MAC.txt
Now I have convert the noe 8038 to SIP, but the tftp config dowload fail, it take the DHCP ip but don'ìt contact the server
Is the procedure correct or do I miss something?
Ps. Reinoud or cavagnaro please, give me feedback
Thank's everybody
Carlo
carlocarlo
can anyone help me?
infoso
Post by infoso »
carlocarlo wrote: 11 Oct 2018 05:29 Hi everybody,
I only ask myself if the procedures descibed are good also for 8038 models?
noesip8038N
datsip8038N-header
datsip8038N
The user Vad suggested me to search this files on /usr2/downbin folder on customer OXE for make the conversion procedure successful.
sipconfig.txt
sipconfig.txt
sipconfig-mac.txt
sipconfig-MAC.txt
for provisioning the phone, are they correct for my model?.
Thank's everybody
Carlo
I have the same Problem. Can anyone help?
carlocarlo
UP my post
I guess you replace the MAC word by your actual phone Mac address, right?
carlocarlo
What?
No, now my deskphone 8038 is SIP but in the start up boot fail the search tftp.
I config the tftp on dhcp server but ignore it and the tcpdump not display what is doing.
Which dhcp server you are using? Which guide and options did you configured?
carlocarlo
tftp-hpa 0.49 on Asterisk(param option tftp-server-name), now see with tcpdump:
ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.199.205 tell 0.0.0.0, length 46
ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.199.205 tell 192.168.199.205, length 46
ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.199.254 tell 192.168.199.205, length 46
ARP, Ethernet (len 6), IPv4 (len 4), Reply 192.168.199.254 is-at 00:50:56:a2:2f:fb, length 28
IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 60)
192.168.199.205.1024 > 192.168.199.254.https: Flags [S], cksum 0x45da (correct), seq 4019368937, win 16384, options [mss 1460,nop,wscale 0,nop,nop,TS val 2777 ecr 0], length 0
IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 52)
192.168.199.254.https > 192.168.199.205.1024: Flags [.], cksum 0xbf25 (correct), seq 1554, ack 849, win 130, options [nop,nop,TS val 3136607160 ecr 3073], length 0
IP (tos 0x0, ttl 64, id 1, offset 0, flags [none], proto TCP (6), length 40)
192.168.199.205.1024 > 192.168.199.254.https: Flags [R], cksum 0x6871 (correct), seq 1888075789, win 0, length 0
IP (tos 0x0, ttl 64, id 2, offset 0, flags [DF], proto TCP (6), length 60)
192.168.199.205.1024 > 192.168.199.254.https: Flags [S], cksum 0x44ae (correct), seq 4019368937, win 16384, options [mss 1460,nop,wscale 0,nop,nop,TS val 3077 ecr 0], length 0
192.168.199.254.https > 192.168.199.205.1024: Flags [S.], cksum 0x2416 (correct), seq 418542746, ack 4019368938, win 14480, options [mss 1460,nop,nop,TS val 3136610158 ecr 3077,nop,wscale 7], length 0
IP (tos 0x0, ttl 64, id 3, offset 0, flags [DF], proto TCP (6), length 52)
192.168.199.205.1024 > 192.168.199.254.https: Flags [.], cksum 0x4491 (correct), seq 1, ack 1, win 17376, options [nop,nop,TS val 3077 ecr 3136610158], length 0
IP (tos 0x0, ttl 64, id 4, offset 0, flags [DF], proto TCP (6), length 569)
192.168.199.205.1024 > 192.168.199.254.https: Flags [P.], cksum 0x3689 (correct), seq 1:518, ack 1, win 17376, options [nop,nop,TS val 3078 ecr 3136610158], length 517
IP (tos 0x0, ttl 64, id 44007, offset 0, flags [DF], proto TCP (6), length 52)
192.168.199.254.https > 192.168.199.205.1024: Flags [.], cksum 0x85e3 (correct), seq 1, ack 518, win 122, options [nop,nop,TS val 3136610172 ecr 3078], length 0
IP (tos 0x0, ttl 64, id 44008, offset 0, flags [DF], proto TCP (6), length 978)
192.168.199.254.https > 192.168.199.205.1024: Flags [P.], cksum 0x14e2 (incorrect -> 0x9537), seq 1:927, ack 518, win 122, options [nop,nop,TS val 3136610172 ecr 3078], length 926
IP (tos 0x0, ttl 64, id 5, offset 0, flags [DF], proto TCP (6), length 242)
192.168.199.205.1024 > 192.168.199.254.https: Flags [P.], cksum 0x0ae8 (correct), seq 518:708, ack 927, win 17376, options [nop,nop,TS val 3081 ecr 3136610172], length 190
IP (tos 0x0, ttl 64, id 44009, offset 0, flags [DF], proto TCP (6), length 103)
192.168.199.254.https > 192.168.199.205.1024: Flags [P.], cksum 0x1177 (incorrect -> 0xa1b8), seq 927:978, ack 708, win 130, options [nop,nop,TS val 3136610206 ecr 3081], length 51
IP (tos 0x0, ttl 64, id 6, offset 0, flags [DF], proto TCP (6), length 161)
192.168.199.205.1024 > 192.168.199.254.https: Flags [P.], cksum 0xf4ed (correct), seq 708:817, ack 978, win 17376, options [nop,nop,TS val 3082 ecr 3136610206], length 109
IP (tos 0x0, ttl 64, id 44010, offset 0, flags [DF], proto TCP (6), length 596)
192.168.199.254.https > 192.168.199.205.1024: Flags [P.], cksum 0x1364 (incorrect -> 0x83eb), seq 978:1522, ack 817, win 130, options [nop,nop,TS val 3136610218 ecr 3082], length 544
IP (tos 0x0, ttl 64, id 44011, offset 0, flags [DF], proto TCP (6), length 83)
192.168.199.254.https > 192.168.199.205.1024: Flags [P.], cksum 0x1163 (incorrect -> 0x610d), seq 1522:1553, ack 817, win 130, options [nop,nop,TS val 3136610218 ecr 3082], length 31
IP (tos 0x0, ttl 64, id 44012, offset 0, flags [DF], proto TCP (6), length 52)
192.168.199.254.https > 192.168.199.205.1024: Flags [F.], cksum 0x7e6d (correct), seq 1553, ack 817, win 130, options [nop,nop,TS val 3136610218 ecr 3082], length 0
IP (tos 0x0, ttl 64, id 7, offset 0, flags [DF], proto TCP (6), length 52)
192.168.199.205.1024 > 192.168.199.254.https: Flags [.], cksum 0x3d4d (correct), seq 817, ack 1554, win 16801, options [nop,nop,TS val 3083 ecr 3136610218], length 0
IP (tos 0x0, ttl 64, id 8, offset 0, flags [DF], proto TCP (6), length 83)
192.168.199.205.1024 > 192.168.199.254.https: Flags [P.], cksum 0x5b28 (correct), seq 817:848, ack 1554, win 17345, options [nop,nop,TS val 3083 ecr 3136610218], length 31
IP (tos 0x0, ttl 64, id 9, offset 0, flags [DF], proto TCP (6), length 52)
192.168.199.205.1024 > 192.168.199.254.https: Flags [F.], cksum 0x3aee (correct), seq 848, ack 1554, win 17376, options [nop,nop,TS val 3083 ecr 3136610218], length 0
IP (tos 0x0, ttl 64, id 44013, offset 0, flags [DF], proto TCP (6), length 52)
192.168.199.254.https > 192.168.199.205.1024: Flags [.], cksum 0x7e46 (correct), seq 1554, ack 849, win 130, options [nop,nop,TS val 3136610224 ecr 3083], length 0
nothing else
? What? You must configure a DHCP server as indicated as documentation and there specify your TFTP address. You can't come with your own ideas...please follow documentation and search the forum for initial steps.
Return to “Asterisk”
