4XX8EE Phones with Asterisk
krzysioD
Re: 4XX8EE Phones with Asterisk
Well Cav,
if you say 'by docs only 4008/4018 can go with sip' you are 100% correct.
But 4028,4038,4068 also go in sip mode. Simply ALU has very, very accurate docs and don't mention about some phones or capabilities.
Of course - extended edition only.
? Well...lol
And which binaries do you have to use?
krzysioD
noesip4028G size: 2277659B
datsip4028G size: 928504B
named as: 2.12.20, released about 21.03.2016
you must forget about 'softkeys' and 'call-by-name' and it works (well, menu is first 5 languages only, not every language in ALU PBX offer but it works).
tangala
thajacabela
I've trying with SIP iptouch 40x8. Devices are working but I have some errors on initialization and I can't get spanish language menu, only english, using 'supported_language=4' (in sipconfig.txt and sipconfig-MAC.txt)
model 4018 (but the same in 4028 and 4038)
Version: sipc 2.12.40 SIP
Intialization errors:
Config files:
sipconfig.txt
sipconfig-mac.txt
I cant put spanish language with settings menu on phone hard buttons.
It could be a problem with sipc 2.12.40 ? (How can I downgrade software version? )
Thanks in advance, and sorry my english
USER.DEBUG: sipconfig_init: error in lldp inventory asset id
USER.DEBUG: sipconfig_load_sip_server_type:Get sip_server_type failed! default is SIP_SERVER_TYPE_OXE
USER.DEBUG: fail to get the company_phone
USER.DEBUG: appui_call_ring():failed to get melody setting \n
USER.DEBUG: DISPLAY: ui_setprop(13):not created!
## the same for (13)(13)(15)(15)(15)(16)
USER.DEBUG: DISPLAY: ui_object_setprop(0x80d3b9d0):no this property!
## the same as before, for (14)(14)(16)(16)(15)(16)
## the same as before, for (13)(13)(15)(15)(15)(16)
sipconfig.txt
sipconfig-mac.txt
thajacabela
Solved !
param 'language' working ( and not working 'supported_language' ) in v2.12.40
[appl]
language=4
# 0=>English, 1=>French, 2=>German, 3=>Italian, 4=>Spanish, 5=>Dutch, 6=>Portuguese
thx 4 sharing...
regards...
regards...
soportecobendai
I have two-thousand 4018EE phones. I need to configure this phones to CUCM (Cisco Unified Communications Managuer). Please, i need help to configure a ftp server and load the configuration files
