4XX8EE Phones with Asterisk
rpsouza
Re: 4XX8EE Phones with Asterisk
Post by rpsouza »
Hi all!
I´m using the ip touch 4018 with Elastix and till now, everything goes well! But as I have many devices I would like to use DHCP config to set the TFTP address automatically.
I´m almost there, I created a TFTP server, put lanpbx.cfg/sipconfig-mac.txt files in it and set the DHCP server like attached image, but now my device keep saying: HTTP DOWNLOAD ERROR and after this I received this message: WRONG PARAMETER.
Can someone help me?
Thanks in advance!
Renato
csic
Post by csic »
fbird wrote:Firmware files:
http://en.file-upload.net/download-1141 ... G.zip.html
http://www.xup.in/dl,39213711/FW_40x8(G).zip/
http://www.megafileupload.com/6l8m/FW_40x8(G).zip
FW_40x8(G).zip Contains:
2.12.00_4018_40x8G/
2.12.00_4018_40x8G/noesip4018
2.12.00_4018_40x8G/datsip40x8G
2.12.00_4018_40x8G/noesip40x8G
2.12.00_4018_40x8G/datsip4018
2.12.20_40x8G/
2.12.20_40x8G/datsip4028G
2.12.20_40x8G/noesip4028G
md5sum:
c8ec5c31b91e7845e66a46abf6bddbd6 FW_40x8(G).zip
The 4028G can be used for 4028EE & 4038 EE.
4018 can be used with 4008 & 4018.
Are the 2.12.00 the latest firmware? Thank you. Is there any web where we can download the latest one?
alca_chris
Post by alca_chris »
Hi, I managed to connect a 4038EE to a Fritzbox using Reynoud's config file. Unfortunately, the phone reboots every few minutes after the following syslog message:
app_call_set_sip_mode:set to standardmode and reset
What does this mean?
This is the config file. Any help would be highly appreciated.
[dns]
## The primary DNS IP address HAS TO BE FILLED
## If no DNS, use the SIP proxy address instead
   dns_addr=192.168.178.2
   dns2_addr=
   hostname=fritz.box
[sip]
## Domain name : IP address, FQDN or domain name (see the SIP proxy config)
   domain_name=192.168.178.2
## Primary SIP proxy and SIP registrar settings
## Proxy address : IP address, FQDN or domain name
## Registrar address : IP address, FQDN or domain name (usually, the proxy)
## SIP proxy UDP port : usually 5060
## SIP registrar UDP port : by default 5060
   proxy_addr=192.168.178.2
   proxy_port=5060
   registrar_addr=192.168.178.2
   registrar_port=5060
   outbound_proxy_addr=
   outbound_proxy_port=
## Redundancy settings
## sip_transport_mode_survi : Transport mode in PCS mode
##          0 = UDP or TCP
##                  1 = UDP
##                  2 = TCP
   proxy2_addr=192.168.178.2
   proxy2_port=5060
   registrar2_addr=192.168.178.2
   registrar2_port=5060
   outbound_proxy2_addr=
   outbound_proxy2_port=
   pcs_addr=192.168.178.2
   pcs_port=5060
   sip_transport_mode_survi=0
   option_timer=120
## Global SIP parameters
## Transport mode : 0 = UDP or TCP
##                  1 = UDP
##                  2 = TCP
## local_rtp_port : RFC3605 is not supported in this release, so
##                  only default value can be used
## PRACK type : 0 = PRACK supported
##              1 = PRACK required
##              2 = PRACK disabled
## Codec settings : 0 = G711 (PCMU)
##                  4 = G723.1
##                  8 = G711 (PCMA)
##                 18 = G729A
   register_expire=3600
   register_retry=300
   local_sip_port=
   sip_transport_mode=0
   local_rtp_port=42000
   local_rtcp_port=42001
   prack_type=0
   preferred_vocoder=8,0,4,18
## SIP authentication.
## Realm : If no authentication, leave empty
## Authentication name : HAS TO BE FILLED
##                       If no authentication, PUT A VALUE LIKE none
## Authentication password : If no authentication, leave empty
   authentication_realm=192.168.178.2
   authentication_name=620
   authentication_password=6200
   user_name=620
   display_name=Alcatel-1
## Voicemail settings
## Voice mail URI : directory number of the voice mail
## user name : directory number of the set
## MWI URI : complete SIP URI of the voice mail
   voice_mail_uri=
   message_waiting_indication_uri=
[qos]
## SIP & RTP DIFFSERV : [0,63]
## SIP QOS Tickets : 0 = disable
##           1 = enable
## SIP QOS Tickets Target : domain name
   sip_diffserv=0
   rtp_diffserv=0
   sip_qos_tickets_enable=0
   sip_qos_tickets_target=
[sntp]
## SNTP server settings (can be OXE or an external server)
## Timezone construction : UT::60:032902:102503
##          GMT delta : 60 = + sixty minutes from GMT time
##          Daylight saving start (mmddhh) : 032902 = 29 March 2am
##          Daylight saving end (mmddhh) : 102503 = 25 October 3am
## The daylight saving settings HAVE to be changed each year.
   sntp_addr=192.168.178.2
   timezone=UT::60:032902:102503
[telnet]
## Password to access the telnet session
   telnet_password=0000
[arp]
## Mode : 0 = ARP spoofing disabled
##        1 = ARP spoofing enabled
   arp_spoofing_enable=1
   arp_spoofing_timer=30
[init]
## For IP Touch with SIP binary in 1.xx, 2.00.10 and 2.00.20, equal or greater than 2.00.81
##     mode 0 = SIP
##     mode 1 = NOE
## For IP Touch with SIP binary 2.00.30 to 2.00.80
##     mode 0 = NOE
##     mode 1 = SIP
   application_mode=0
[audio]
## Tone country : 0 = English
##                1 = French
##                2 = German
##                3 = Italian
##                4 = Spanish
##                5 = Dutch
##                6 = Portuguese
## DTMF type : 0 = RFC2833
##             1 = In-band
##             2 = SIP INFO
## DTMF level / RLR handset / SLR handset / Sidetone handset :
## 0 = 0db, 1 = +3db, 2 = +6db, 3 = -3db, 4 = -6db
## VAD / DTMF feedback / Hearing Aid :
##       0 = VAD not used
##       1 = VAD used
   tone_country=2
   dtmf_type=1
   dtmf_level=0
   dtmf_avt_payload_type=96
   vad=0
   dtmf_feedback_enable=0
   rlr_handset=0
   slr_handset=0
   sidetone_handset=2
   hearing_aid_enable=0
[appl]
## Password to access the administrator menu on the phone (digits only)
## Power priority : 1 = critical
##                  2 = high
##                  3 = low
## Time format : 0 = 24 hours format
##               1 = AM / PM
## Speed dial numbers (first and last name, URI)
   admin_password=000000
   bluetooth_parameters=blue
   supported_language=0
   remote_forward_code=
   remote_forward_deactive_code=
   power_priority=3
   asset_id=
   time_format=
   speed_dial_1_first_name=
   speed_dial_1_last_name=
   speed_dial_1_uri=
   speed_dial_2_first_name=
   speed_dial_2_last_name=
   speed_dial_2_uri=
   speed_dial_3_first_name=
   speed_dial_3_last_name=
   speed_dial_3_uri=
   speed_dial_4_first_name=
   speed_dial_4_last_name=
   speed_dial_4_uri=
[admin]
## Global admin parameters
## Binary polling timer : 10 min - 65535 min (default 480 min)
## Config polling timer : 5 min - 65535 min (default 60 min)
   binary_polling_timer=480
   config_polling_timer=60
   disable_pc_port=0
   activate_vlan_filter=0
Reinoud
Post by Reinoud »
Hey Chris,
I had the same error and fixed it with the following settings:
	proxy2_addr=
	proxy2_port=
	registrar2_addr=
	registrar2_port=
	pcs_addr=
	pcs_port=
	option_timer=0
As I recall the option timer did the trick...
rgds,
Reinoud
alca_chris
Hi Reinoud,
thanks a lot, that worked!
Did you succeed to use any other function of the set, e.g. the MWI or the FritzBox Phonebook? I can add entries locally at the phone, but the entries in the config file (speed_dial_1...) are ignored.
regards,
Chris
Reinoud
Post by Reinoud »
MWI works, although I don't use voicemail... I didn't try the phonebook...
alca_chris
Ok, so what did you set for the following config items? I am not sure, which one gets the handset number and which one the Mailbox and in what format:
   voice_mail_uri=**600
   message_waiting_indication_uri=**620@192.168.178.2
regards,
Chris
Reinoud
Post by Reinoud »
**600 is my voicemail/answering machine in fritz.box (which I actually don't use), **620 is my Alcatel-Lucent SIP set.
gholi
Post by gholi »
Hello Reinoud,
I have a problem with 4008 connecting to asterisk. I think you can help me.
Is it possible to contact you in person?
gholi
Post by gholi »
Does anybody here have an alcatel-lucent 4008 EE set ?
If yes, please contact me.
Return to “Asterisk”
