This is the error from my first post.
READ !
[VALIDATED] - eyeBeam
- frank
Just dial ***7469 on the phone ...
You will have a setup menu showing up ...
In the filter, look for "session" (without the " " )
Then look for the line "system:sdp:include_x_rtp_session_id" and replace the 1 by 0.
If you can't find this option, then it's because it's not implemented in your x-lite release (it was not for me, I had to get eyeBeam) .
The programmers told me that they would add it in the next release for x-lite
Some results of my investigations.
I have two versions of X-Lite 2.0 and 3.0 on different computers.
With OXE SW R6.2-f3.301-10 two clients work fine - both with digest authorisation and without authorisation. I upgraded OXE to SW 7.1 (f4.401.13) and checked (so both clients do not know with which SW version of switch they work
So both do not work! But with different behaviour.
X-Lite 2.0 logged OK. But when dialling any number (internal or external)- message "Temporarily not available" is displayed.
X-Lite 3.0 logged OK. But when dialling a number - message "Bad request"
Logs are available for these calls.
X-Lite 2.0 - release 1105
X-Lite 3.0 - release 1002tx stamp 29712 (CounterPath eyeBeam)
freedom
I have the problem also, but....
The other way around!
On release 7 (F440116) the phone works fine, but on a relase 6.2 (F330122) I receive a 'bad request' message if I dial from X-Lite to OXE, and if I call from OXE to X-Lite I can answer the call, but the OXE set keeps calling.
I have already changed the suggested parameter, but this will not help.
I hope to find a difference in both systems that can explain the problems.
