incvisu log
- tot3nkopf
Re: incvisu log
Remove sychro from domain 1 also and see what happens. Also please post your INTIP's configuration and general architecture of the system (IP's , etc).
thkim81
Re: incvisu log
i did your reply but my sync status is nothing.
i attached my site INTIP infomation.
The other information that i don't know what did give you ?
hm..
hm..
- tot3nkopf
Re: incvisu log
Hmm....Never seen something like this (usually when this happens it is a synchro problem).
Last idea: swich intof cards between shelfs (ex: intof 1 0 with 2 22). If an upgrade is performed somtimes the remote intof doesn't download the new version. Don't know if this is your case, but I ran out of ideas. Gents: any other comments onto this?
Re: incvisu log
Yes it is synchro proble. Main shelf is not in sync with PTT even if "infocs" reports OK.tot3nkopf wrote:Hmm....Never seen something like this (usually when this happens it is a synchro problem).
I have seen such a problem but on release 6.1.1. All INTOFs had to be replaced back then.
Reading of TC 563 Ed.02 is strongly recommended.
thkim81
Re: incvisu log
thanks your reply.
i will switch board place soon.
if it's not method that i feel your reply huge support to me
thanks
thanks your reply.
thanks
thkim81
Re: incvisu log
alex
Is TC 563 Ed.02 document right?
I don't know Where is that document ?
and My site INTOF board is another board
hm.. INTOF is add some board new Version board
now INTOF board are two years ago Board + new Version board
Each Shelf is Mixed Board .
May be, Is this thing(INTOF Version Mixed) caused Sync problem ?
pls reply my question.
thanks
thanks
thkim81
Re: incvisu log
thkim81 wrote:alex
thanks
thkim81
Re: incvisu log
alex
site OXE is ver 9.0.
thanks[/quote][/quote]
rodrinkhome
Re: incvisu log
Good morning,
I have a problem with logs and by using this issue maybe someone can help me.
Since 11/06/20 I can't get any logs in my OXE. I don't know why was happened because we didn't make any change
I was looking how to restart them but I didn't find anything. Everthing is working correctly but I would like to see what is going on by watching logs.
Here is some information about my OS: Linux va_ct01 2.6.32-ll-dhs3 #1 Wed Apr 18 13:21:34 IST 2018 i686 i686 i386 GNU/Linux
Thanks.
Thanks.
