Not, it's not ok. System will go back to default value (5 as per docs).PeEs wrote:i try to search it and found parameters.cfg is in /usr3/afe , when i use "vi" command and see the list :krzysioD wrote:Ah, my memory fails: file named parameters.cfg in DHS3dyn/afe
search for line staring with: period1
change 5 to 15
description: 1 .. 15 : Statistic counters are stored during 1 to 15 weeks
btw: you need full restart (not a bascul) to do it... and do it on both cpus.
weeks_period1 5
other question is .... is it ok if we edit weeks_period1 more than 15 weeks?
Note: description of lines does not matter, only the order of entries and values does matter.
