That is done. Same problem.freedom wrote:You say the GD was corrupted.
Already tried changing the GD by a different one?
GD IN SERVICE BUT OTHER BOARDS OUT OF SERVICE
lifeboat_DUP
Re: GD IN SERVICE BUT OTHER BOARDS OUT OF SERVICE
- tot3nkopf
Try to reload the last OPS (all the files -- not just .swk) again, reboot, and see if this corrects the problem--->maybe memory aloc problem (we had such a case around here).
Regards.
Regards.
No Toten. It wouldn't help. This is main rack(GD)+extension rack system. Extension rack works fine but in main rack all boards are out-of-service. Looks like problem with GD or rack itself.tot3nkopf wrote:Try to reload the last OPS (all the files -- not just .swk) again, reboot, and see if this corrects the problem--->maybe memory aloc problem (we had such a case around here).
Regards.
As I wrote already I've been thru this problem.
- tot3nkopf
lifeboat_DUP
I brought a new shelf to local, same problem. Can it be issue with the client's LAN?alex wrote:No Toten. It wouldn't help. This is main rack(GD)+extension rack system. Extension rack works fine but in main rack all boards are out-of-service. Looks like problem with GD or rack itself.tot3nkopf wrote:Try to reload the last OPS (all the files -- not just .swk) again, reboot, and see if this corrects the problem--->maybe memory aloc problem (we had such a case around here).
Regards.
Lifeboat - look like you not say all information - show config all and explain more complete your problem.
f.e. - remote shelf or extention? If last one - connected with standart cabel?
GD - it was GD from the begining (not modified CPU from OXE) and so on.
GD or GD-2? What exactly your release?
Was some problem before (we have some message from Alex)?
