IP SoftPhone via IPSec VPN
Re: IP SoftPhone via IPSec VPN
did u create the route from OXE to the subnet 10.0.11.10 to 20 with the gateway @ at netadmin-m /8 static route
sadim
Post by sadim »
Can the phone at least download the lanpbx.cfg file through tftp or the download of this file also fails?
correction
route to the subnet 10.0.111.10 to 20
sirlawnmower
Post by sirlawnmower »
Well, we did that wireshark capture. And, as I said before, when de IP Desktop Softphone is ran in the client PC, it tries to get three small files from the OXE via TFTP. In the "local" client PC, this process is accomplished within few seconds. In the "remote" PC (through the IPSec VPN), the app tries to get those files, but the TFTP process times out after ten attempts.
alexeik
Post by alexeik »
now i would do a tcpdump on oxe to see if the tftp pakets reaches the OXE from VPN or not.
And have a look at the live log of the firewall if you see packets in both directions...
sirlawnmower
That's a pretty good idea, thx...
Zuckerwasser
Post by Zuckerwasser »
Hello, do you solve the problem and give me a advice?
most likely a route issue somewhere or IP misconfiguration
you need to make sure the PBX know how to talk to the phones. from the PBX, can you ping the remote laptop once on the vpn?
Return to “IP”
