Call transit is disconnect
Re: Call transit is disconnect
Local user dial AC619924 as in your example for incoming calls?
I don't think so.
Can you explain exactly - what dial internal user.
juruna wrote: 20 Oct 2020 11:45
1.Ext 4067(NEC) call to all other user 9924.
2.OXE(1) receive the number 619924 translate to format AC619924(ARS prefix+number) and the call is DISCONNECT.
I tried to translate it to an abbreviated(#*61) one which in turn dialed AC619924 and the call is DISCONNECT again.
[ISDN log]
| (722617:000023:05023) Concatenated-Physical-Event :
| long: 45 desti: 0 source: 0 cryst: 3 cpl: 6 us: 0 term: 0 type a5
| tei: 0 >>>> message received : SETUP [05] Call ref : 6d 00
| IE:[04] BEARER_CAPABILITY (l=3) 90 90 a3
| IE:[18] CHANNEL (l=3) a9 83 94 -> T2 : B channel 20 exclusive
| IE:[6c] CALLING_NUMBER (l=5) -> 80 Num : 4067
| IE:[70] CALLED_NUMBER (l=7) -> 80 Num : 619924
| [a1] Sending complete
Thanks and regards!
abbreviated NUMBER is the issue , i remember a case wich i got in 2009 that Abv number doesn't work in transit mode ISDN TO QSIG ;
IN THE TRACE youshould see only the called number without other prefixs
61 SHOULD BE ROUTING NUMBER
juruna
Post by juruna »
My client don't have a numbering plan homogenius, there are many conflicts.
I need to use ARS to call other sites with SIP protocol without consuming the numbering plan.
look 4067(nec) calls 9924
OXE Rreceive 619924 INSTEAD of 9924 SO 61is added by nec and it's not a part of that called number right?
if the wished number is 9924 AND unfortunatly nec can't remove that 61, a workaround is to use did translation or unused numbers length , and routing number or ars should work.
btw calls from oxe to all are 4digits? can u post a trace ?
What dial OXE(1) user for calling to 9924
Explain you management in OXE(1) for calling to 9924 (ARS, Network/routing prefix).
If OXE (1) user just dial 9924 - for call from NEC you can manage DID rules - 619924 --> 9924
juruna
Post by juruna »
AC is a ARS prefix.
+-Consult/Modify: Prefix Plan---------------------------------------------+
|                             Number : AC                                 |
|                     Prefix Meaning + ARS Prof.Trk Grp Seiz.with overlap |
|                  Discriminator Nr. : 6                                  |
All OXI users have the 74 (F2) key programmed with the prefix AC.
+-Consult/Modify: Progr.Keys--------------------------------------------+
|                   Directory Number : 1000                             |
|                            Key No. : 74                               |
|                           Function + Programmed                       |
|      Mnemo(Pocket,Mobile,4040,8&9) : --------------                   |
|           UTF-8 Mnemo (8&9 Series) : -------------------------------  |
|                            Content : AC                               |
|                             Locked + NO                               |
Then to talk to set 9924 on OXE (2), dial F2 (AC) +619924.
+-Consult/Modify: Discriminator Rule---------
|                  Discriminator Nr. : 199
|                        Call Number : 61
|                        Area Number : 1
|              ARS Route List Number : 61
|                    Schedule Number : -1
|                   Number of Digits : 6
The dialing rule directs to the ARS route list 61.
+-Consult/Modify: ARS Route---------------------------------------
|                     ARS Route list : 61
|                              Route : 1
|                 Trunk Group Source + Route
|                        Trunk Group : 903
|            Nb.Digits To Be Removed : 2
|                      Digits To Add : ---------------------------
|          Numbering Command Tabl.ID : 161
|                     VPN Cost Limit : 0
|                      Protocol Type + Dependant on Bundle Type
|                     NPD identifier : 255
|                         Route Type + Public
|                     ATM Address ID : -1
|                          Preempter + False
+-Consult/Modify: Numbering Command Table-----
|                           Table ID : 161
|                  Carrier Reference : 0
|                            Command : I
|             Associated SIP gateway : 161
The NEC user forwards the number 619924, I use the DDI table to add the #*.
+-Consult/Modify: DDI number translator rules----
|             Node Number (reserved) : 11
|                Instance (reserved) : 1
|        DDI num. transl. identifier : 5
|              First External Number : 610000
|              First Internal Number : #*610000
|                         Range Size : 10000
|             Unique Internal Number + NO
and finally, speed dial #*61 calls AC (ARS prefix).
+-Consult/Modify: Direct Abbrev.No Pref.-----------
|              Direct Abbr.No Prefix : #*61
|                        Call Number : AC61
|                     Directory name : ------------
|               Directory First Name : ------------
|               UTF-8 Directory Name : ------------
|         UTF-8 Directory First Name : ------------
|                            Barring + False
|         Overfl.Dir.Abbrev.No Pref. : --------
|       Auto.Attendant Calling Right : 0
|                          Call Type + Normal
|       Timed Forward.Dir.Abbrev.No. : --------
|                       Range Number : 255
|              Can Be Called By Name + NO
|                     Displayed Name : AC61
|              External DISA Dir.No. : --------
T3 log with speed dialing
mtracer started ...
(041359:000001:06241) MTRACER host (10.193.80.30, ssp0754), version: R12.0-m1.403-27-br-c0s1
(041359:000001:06241) MTRACER num: 008, time: 2020/11/20 15:57:23, loss: 0%
| (041430:000002:03872) Concatenated-Physical-Event :
| tei: 0  >>>>  message received : SETUP [05]    Call ref :  10 02
| IE:[18] CHANNEL (l=3)  a9 83 87 -> T2 : B channel 7 exclusive
| (041430:000003:03842) 3842: Send_IO1 (link-nbr=2, sapi=0, tei=0) :
| long: 23  desti: 0  source: 15  cryst: 3  cpl: 6  us: 8  term: 0  type a5
| tei: 0  <<<<  message sent : CALL PROC (02)  Call ref :  90 02
| (041430:000004:03842) 3842: Send_IO1 (link-nbr=2, sapi=0, tei=0) :
| long: 22  desti: 0  source: 15  cryst: 3  cpl: 6  us: 8  term: 0  type a5
| tei: 0  <<<<  message sent : DISCONNECT [45]  Call ref :  90 02
| IE:[08] CAUSE (l=2) 81 90 -> [90] NORMAL CALL CLEARING
| (041431:000005:03872) Concatenated-Physical-Event :
| long: 18  desti: 0  source: 0  cryst: 3  cpl: 6  us: 0  term: 0  type a5
| tei: 0  >>>>  message received : RELEASE [4d]   Call ref :  10 02
| (041431:000006:03842) 3842: Send_IO1 (link-nbr=2, sapi=0, tei=0) :
| tei: 0  <<<<  message sent : REL COMP [5a]  Call ref :  90 02
| (041457:000007:03872) Concatenated-Physical-Event :
| long: 22  desti: 0  source: 0  cryst: 2  cpl: 0  us: 0  term: 0  type a5
| tei: 0  >>>>  message received : RELEASE [4d]   Call ref :  00 22
| IE:[08] CAUSE (l=2) 81 83 -> [83] NO ROUTE TO DESTINATION
T3 log using AC(ARS prefix) directly
mtracer started ...
(045081:000001:06495) MTRACER host (10.193.80.30, ssp0754), version: R12.0-m1.403-27-br-c0s1
(045081:000001:06495) MTRACER num: 009, time: 2020/11/20 16:03:35, loss: 0%
| (045139:000002:03872) Concatenated-Physical-Event :
| tei: 0  >>>>  message received : SETUP [05]    Call ref :  13 02
| IE:[18] CHANNEL (l=3)  a9 83 93 -> T2 : B channel 19 exclusive
| (045139:000003:03844) 3844: Send_IO1 (link-nbr=2, sapi=0, tei=0) :
| tei: 0  <<<<  message sent : CALL PROC (02)  Call ref :  93 02
| (045139:000004:03844) 3844: Send_IO1 (link-nbr=2, sapi=0, tei=0) :
| tei: 0  <<<<  message sent : DISCONNECT [45]  Call ref :  93 02
| (045140:000005:03872) Concatenated-Physical-Event :
| tei: 0  >>>>  message received : RELEASE [4d]   Call ref :  13 02
| (045140:000006:03844) 3844: Send_IO1 (link-nbr=2, sapi=0, tei=0) :
| tei: 0  <<<<  message sent : REL COMP [5a]  Call ref :  93 02
The SIP log does not display anything.
i think from oxe1 to panasoniC actually you're not sending 61xxxx as your ars list 61 remove two digits.
this message is received from panasonic
| IE:[08] CAUSE (l=2) 81 83 -> [83] NO ROUTE TO DESTINATION.
so The call routes through an intermediate network that does not serve the destination address. This cause indicates that the called user is not reachable. A user is not reachable when the network used to route the call does not serve the required destination.
can you check on the panasonic side what's actually receiving as setup from oxe1 when a local user calls to 61xxxx and when nec local user is calls to.?
and kindly can u past log at oxe 1 side for a local user call to the transit net(panasonic -----oxe2]?
in the oxe1 61 Is used for local numbering plan or not ? same for 9 , 99
for sip malfunctioning
trkstat 903 shows chanals F / hs
MAY be you have to restart the sip process or double bascul if duplicated sys
vad wrote: 21 Oct 2020 23:29 Check with lookars (may be time-based route list not managed) or route call to internal number.
F.e. in route list 61 manage for test - TG id=-1 (internal route), delete 6, add XXXX (some internal number).
If call will be routed to internal number XXXX - with management Ok up to route list.
juruna wrote: 23 Oct 2020 11:29 - lookars is OK
- I change the route list 61 for internal route but not work
[T3 log]
| (304477:000023:05023) Concatenated-Physical-Event :
| tei: 0 >>>> message received : SETUP [05] Call ref : 23 04
| IE:[18] CHANNEL (l=3) a9 83 91 -> T2 : B channel 17 exclusive
| (304477:000024:04992) 4992: Send_IO1 (link-nbr=2, sapi=0, tei=0) :
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : a3 04
| (304477:000025:04992) 4992: Send_IO1 (link-nbr=2, sapi=0, tei=0) :
| tei: 0 <<<< message sent : DISCONNECT [45] Call ref : a3 04
| IE:[08] CAUSE (l=2) 81 9b -> [9b] DESTINATION OUT OF ORDER
but here you have'nt made the necessary changes as suggested by @Vad; so 619924 doesnt exist in oxe
Return to “Trunk Groups”
