SIP Failed for OXE and Avaya IPO 500
Re: SIP Failed for OXE and Avaya IPO 500
The information is not enough. Need to see all the sip headers and no truncating
BRegards
BRegards
Thanks for reply.
Please see the attached wireshark file for one call.
@ vad done doing incvisu with result attached.Also motortrace.Dont seem to find anything with SIP
For incident - use command "incvisu" (or "incvisu -t 100" - 100 last incidents). With "-b 1" - you have incidents from previous telephone session.
You have nothing in motortrace?
Show trkstat output.
edit self correction
In one topic two active person with different problem.
kimy we need traces
OXE>motortrace 3
OXE> traced
also needed
OXE>trkstat (sip abcftg number) as shown in a previous message
OXE>motortrace 3
OXE> traced
also needed
Hi all Thanks for the support. However, just few weeks after the same issue occur again and doing the restart of SIP services by killall sipmotor/dhs3_init -R SIPMOTOR no longer works. Still OXE can't call to AVAYA.Instead i'm getting a major and minor SIP component failure & another issue via incvisu. Please help me. I'm really getting worried.
08/06/20 18:13:20 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:13:20 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:13:24 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:13:24 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:13:28 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:13:28 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:13:32 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:13:32 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:13:40 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:13:40 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:13:41 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:13:41 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:13:42 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:13:42 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:13:44 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:13:44 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:13:48 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:13:48 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:13:52 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:13:52 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:13:56 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:13:56 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:14:00 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:14:00 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:14:04 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:14:04 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:14:08 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:14:08 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:14:12 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:14:12 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:14:25 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:14:25 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:14:26 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:14:26 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:14:27 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:14:27 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:14:29 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:14:29 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:14:35 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:14:35 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:14:39 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:14:39 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:14:43 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:14:43 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:14:47 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:14:47 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:14:51 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:14:51 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:14:55 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:14:55 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:14:59 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:14:59 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:15:03 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:15:03 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:15:12 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:15:12 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:15:13 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:15:13 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:15:14 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:15:14 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:15:16 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:15:16 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:15:20 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:15:20 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:15:24 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:15:24 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:15:28 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:15:28 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:15:35 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:15:35 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:15:36 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:15:36 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:15:37 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:15:37 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:15:39 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:15:39 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:15:43 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:15:43 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:15:47 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:15:47 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:15:51 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:15:51 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:15:55 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:15:55 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:15:59 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:15:59 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:16:03 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:16:03 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:16:07 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:16:07 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:16:30 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:16:30 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:16:31 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:16:31 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:16:32 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:16:32 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:16:34 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:16:34 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:16:38 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:16:38 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:16:42 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:16:42 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:16:46 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:16:46 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:16:50 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:16:50 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:16:54 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:16:54 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:16:58 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:16:58 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:17:02 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:17:02 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:17:06 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:17:06 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:17:07 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:17:07 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:17:08 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:17:08 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:17:10 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:17:10 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:17:14 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:17:14 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:17:18 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:17:18 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:17:22 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:17:22 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:17:26 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:17:26 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:17:30 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:17:30 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:17:32 000001M|---/--/-/---|=2:0275=ACCOUNTING: Appli ACC_ETH : feature incident 10 0
08/06/20 18:17:34 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:17:34 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:17:38 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:17:38 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:17:51 000001S|---/--/-/---|=3:1125=external alarm : "mtcl login"
08/06/20 18:17:59 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:17:59 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:18:00 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:18:00 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:18:01 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:18:01 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:18:03 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:18:03 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:18:07 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:18:07 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:18:11 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:18:11 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:18:15 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:18:15 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:18:19 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:18:19 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:18:23 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:18:23 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:18:27 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:18:27 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:18:31 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:18:31 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:18:38 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:18:38 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:18:39 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:18:39 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:18:40 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:18:40 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:18:42 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:18:42 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:18:46 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:18:46 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:18:50 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:18:50 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:18:54 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:18:54 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:18:58 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:18:58 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:19:02 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:19:02 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:19:06 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:19:06 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:19:10 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:19:10 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:19:30 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:19:30 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:19:31 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:19:31 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:19:32 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:19:32 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:19:39 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:19:39 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:19:40 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:19:40 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:19:41 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:19:41 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:19:43 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:19:43 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:19:47 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:19:47 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:19:51 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:19:51 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:19:55 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:19:55 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:19:59 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:19:59 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:20:03 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:20:03 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:20:07 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:20:07 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:20:11 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:20:11 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:20:33 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:20:33 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:20:34 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:20:34 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:20:35 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:20:35 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:20:37 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:20:37 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:20:41 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:20:41 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:20:45 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:20:45 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:20:49 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:20:49 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:20:53 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:20:53 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:20:57 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:20:57 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:21:01 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:21:01 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:21:05 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:21:05 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:21:11 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:21:11 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:21:12 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:21:12 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:21:13 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:21:13 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:21:15 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:21:15 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:21:15 000001M|---/--/-/---|=2:0275=ACCOUNTING: Appli PRINTING : feature incident 10 22
08/06/20 18:21:21 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:21:21 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:21:22 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:21:22 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:21:23 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:21:23 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:21:25 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:21:25 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:21:29 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:21:29 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:21:33 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:21:33 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:21:37 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:21:37 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:21:41 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:21:41 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:21:45 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:21:45 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:21:49 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:21:49 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:21:53 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:21:53 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:22:05 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:22:05 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:22:06 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:22:06 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:22:07 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:22:07 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:22:14 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:22:14 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:22:15 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:22:15 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:22:16 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:22:16 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:22:18 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:22:18 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:22:23 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:22:23 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:22:24 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:22:24 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:22:25 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:22:25 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:22:27 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:22:27 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:22:31 000001M|---/--/-/---|=2:5815=Major failure in SIP component
08/06/20 18:22:31 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
08/06/20 18:22:31 000001M|000/00/-/---|=1:2346=Bascul command called
08/06/20 18:22:34 000001M|---/--/-/---|=1:2077=CPU was halted due to a shutdown
08/06/20 18:22:35 000001M|000/28/-/---|=0:0416=Too long Restart for IPLINK
08/06/20 18:22:43 000001M|---/--/-/---|=0:2663=IPC Chorus err: appli SP oper 7 err -10
08/06/20 18:22:43 000001M|---/--/-/---|=0:2663=IPC Chorus err: appli MAO_AGENT oper 7 err -10
08/06/20 18:22:44 000001M|---/--/-/---|=0:2663=IPC Chorus err: appli BROADCAST oper 18 err 15
08/06/20 18:22:44 000001M|---/--/-/---|=3:4076=PBM : signal 15 caught
08/06/20 18:22:44 000001M|---/--/-/---|=3:4019=CSTA server : 3840 exit
08/06/20 18:22:45 000001M|---/--/-/---|=2:0275=ACCOUNTING: Appli PRINTING : feature incident 20 15
08/06/20 18:22:46 000001M|---/--/-/---|=0:2663=IPC Chorus err: appli ACC_ETH oper 20 err 15
08/06/20 18:22:46 000001M|---/--/-/---|=0:2663=IPC Chorus err: appli SAVE oper 20 err 15
08/06/20 18:22:46 000001M|---/--/-/---|=2:0275=ACCOUNTING: Appli ASCII : feature incident 20 15
08/06/20 18:22:46 000001M|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : feature incident 20 15
(1)mcia_b_t1>
(1)mcia_b_t1>
