Call logs not showing received numbers in 80x8 series sets
mdhussainvlr
Re: Call logs not showing received numbers in 80x8 series sets
Post by mdhussainvlr »
It’s external no
solven
Post by solven »
Does it show the numbers if an internal phone calls one of them?
mdhussainvlr
Hi have anybody have solution for this ?
Your boards have clip detection? Do you see the number while ringing?
mdhussainvlr
Yes I can able to see the number while ringing phase and if it is not answered and if you try to see in the call log it will show ****
mdhussainvlr
After upgrade to latest 10.3 I can able to see [emoji2]
Nice thanks for sharing the solution
Return to “Applications”
