OS6350 Stacking
mattstover
Re: OS6350 Stacking
Im having an issue where my second switch in me 6350 is randomly crashing and coming back to the stack. Anyone seen this? Just installed these units Friday. We're not using any special stacking cables....just the typical 10Gb/s Direct Attached SFP twin Ax cables like we always use on tons of 6450 stacks.
SUN SEP 02 16:54:10 2018 LINKAGG info Aggregate Down . port: 2006 agg: 3
SUN SEP 02 16:54:10 2018 LINKAGG info Port Leave . port: 2007 agg: 4
SUN SEP 02 16:54:10 2018 LINKAGG info Aggregate Down . port: 2008 agg: 4
SUN SEP 02 16:54:10 2018 LINKAGG info Port Leave . port: 2051 agg: 31
SUN SEP 02 16:54:10 2018 STP info Topology changed on VLAN/STP id 172
SUN SEP 02 16:54:10 2018 STP info Topology changed on VLAN/STP id 1022
SUN SEP 02 16:54:10 2018 HSM-CHASSIS info T8: Ni(2) extraction detected
SUN SEP 02 16:54:10 2018 HSM-CHASSIS info == HSM == csHsmUtilNiCtxBrdSend() nsm CS_HSM_NSM_ST_OP, poweroff 0 Ni2
SUN SEP 02 16:54:10 2018 HSM-CHASSIS info === HSM === Power Supply 2 has been REMOVED
SUN SEP 02 16:54:10 2018 VLAN info CS_NI_DOWN/CS_NI_NOTPRESENT msg Rx for slot 2
SUN SEP 02 16:54:10 2018 VLAN info Del connection for slot 2
SUN SEP 02 16:54:10 2018 VLAN info VMC: Sent Pause for slot 2
SUN SEP 02 16:54:10 2018 VLAN info Start Timer on ni_down 2 @ 1535925250
SUN SEP 02 16:54:10 2018 GM info NI_DOWN 2
SUN SEP 02 16:54:10 2018 GM info Del connection for slot 2
SUN SEP 02 16:54:10 2018 GM info GMC: Sent Pause for slot 2
SUN SEP 02 16:54:10 2018 GM info Start Timer on ni_down 2 @ 1535925250
SUN SEP 02 16:54:10 2018 LINKAGG info EVT board down received slot 2 slice 0 recover 0
SUN SEP 02 16:54:10 2018 ETHERNET-OAM info Timer started Slot: 2, SocketID: 492
SUN SEP 02 16:54:11 2018 STP info Topology changed on VLAN/STP id 1023
SUN SEP 02 16:54:15 2018 STP info Topology changed on VLAN/STP id 1027
SUN SEP 02 16:54:15 2018 GM info Timer closed skt on ni 1 @ 1535925255
SUN SEP 02 16:54:15 2018 VLAN info Timer closed skt on ni 1 @ 1535925255
SUN SEP 02 16:54:15 2018 VLAN info Timer closed skt for GVRP NI on ni 1 @ 1535925255
SUN SEP 02 16:54:15 2018 ETHERNET-OAM info Timer expired Slot: 2, SocketID: 492
SUN SEP 02 16:54:18 2018 STP info Topology changed on VLAN/STP id 1020
SUN SEP 02 16:54:19 2018 STP info Topology changed on VLAN/STP id 1
SUN SEP 02 16:54:19 2018 STP info Topology changed on VLAN/STP id 1021
SUN SEP 02 16:54:20 2018 STP info Topology changed on VLAN/STP id 172
SUN SEP 02 16:54:20 2018 STP info Topology changed on VLAN/STP id 1022
SUN SEP 02 16:54:21 2018 STP info Topology changed on VLAN/STP id 1023
SUN SEP 02 17:04:10 2018 CSM-CHASSIS info == CSM == Stack topology changes have been updated to persistant file
SUN SEP 02 17:04:10 2018 CCM-CHASSIS info === CCM === NI 2 has gone down/removed from host 'vxTarget'
SUN SEP 02 19:02:38 2018 STACK-MANAGER info == SM == Stack Port B Status Changed: DOWN
SUN SEP 02 19:02:38 2018 STACK-MANAGER info == SM == Stack Port A Status Changed: DOWN
SUN SEP 02 19:03:46 2018 STACK-MANAGER info == SM == Stack Port B Status Changed: UP
SUN SEP 02 19:03:46 2018 STACK-MANAGER info == SM == Stack Port B MAC Frames TX/RX Enabled
SUN SEP 02 19:03:46 2018 STACK-MANAGER info == SM == Stack Port A Status Changed: UP
SUN SEP 02 19:03:46 2018 STACK-MANAGER info == SM == Stack Port A MAC Frames TX/RX Enabled
SUN SEP 02 19:03:50 2018 STACK-MANAGER info Retaining Module Id for slot 2 unit 0 as 2
SUN SEP 02 19:03:50 2018 STACK-MANAGER info Retaining Module Id for slot 2 unit 1 as 3
SUN SEP 02 19:03:53 2018 CSM-CHASSIS alert == CSM == P54_1 - Startup hold request received
SUN SEP 02 19:03:53 2018 CSM-CHASSIS alert == CSM == P54_1 - Forwarding Hold Status FALSE response to Secondary CSM
SUN SEP 02 19:03:56 2018 INTERFACE info esm:Disconnection NI 2 Sup, sockid 246
SUN SEP 02 19:03:56 2018 INTERFACE info Got connection from slot 2:226
SUN SEP 02 19:03:58 2018 INTERFACE info Got connection from slot 2:246
SUN SEP 02 19:03:58 2018 CCM-CHASSIS info boot type message from slot 2 NISUP, boot type 1
SUN SEP 02 19:04:07 2018 CSM-CHASSIS alert == CSM == Checksum rcvd from slot 2 in state 14
SUN SEP 02 19:04:07 2018 CSM-CHASSIS alert == CSM == Processing rcvd checksum 0x1bd53ee from slot 2
SUN SEP 02 19:04:07 2018 CSM-CHASSIS alert == CSM == Checksum matches, Slot 2 role CS_SECONDARY is in sync
SUN SEP 02 19:04:12 2018 HSM-CHASSIS info T8: Ni(2) insertion detected
SUN SEP 02 19:04:12 2018 HSM-CHASSIS info == HSM == csHsmUtilNiCtxBrdSend() nsm CS_HSM_NSM_ST_OP, poweroff 0 Ni2
SUN SEP 02 19:04:13 2018 GM info GMC: Got connection from slot 66, connIdx 1
SUN SEP 02 19:04:13 2018 VLAN info VMC: Got connection from slot 66
SUN SEP 02 19:04:13 2018 VLAN info VMC: Connected State will be in state 3
SUN SEP 02 19:04:13 2018 VLAN info MVRP_DUMMY_MSGID message received from NI, otherEnd = 9
SUN SEP 02 19:04:18 2018 HSM-CHASSIS info === HSM === Power Supply 2 has been INSERTED
SUN SEP 02 19:04:18 2018 HSM-CHASSIS info == HSM == Power Supply 2 is OPERATIONAL
SUN SEP 02 19:04:31 2018 HSM-CHASSIS info == HSM == NiNsmT1: NI STATE Rcvd (sl: 2), MsgFlag: 0 Local T.O. Flag: 0
SUN SEP 02 19:04:31 2018 HSM-CHASSIS info == HSM == NI UP Received from driver (sl =2)
SUN SEP 02 19:04:31 2018 HSM-CHASSIS info == HSM == csHsmUtilNiCtxBrdSend() nsm CS_HSM_NSM_ST_OP, poweroff 0 Ni2
SUN SEP 02 19:04:31 2018 VLAN info CS_NI_UP msg received for slot 2 cfgState 1
SUN SEP 02 19:04:31 2018 VLAN info CS_NI_UP InTakeover 0 vmcPrimaryCmm 1 NiDownRx 1
SUN SEP 02 19:04:31 2018 VLAN info CS_NI_UP State will be 3
SUN SEP 02 19:04:31 2018 VLAN info VMC: Sent Ok for slot 2
SUN SEP 02 19:04:31 2018 STP info STPCMM[7951]: sent config end to NI:2
SUN SEP 02 19:04:31 2018 ERP info ERP CMM[544] : Sending end of config from CMM to NI
SUN SEP 02 19:04:31 2018 GM info NI_UP 2
SUN SEP 02 19:04:31 2018 GM info GMC: Sent Ok for slot 2
SUN SEP 02 19:04:31 2018 LINKAGG info EVT board up received slot 2 slice 0 unlike 2 recover 0
SUN SEP 02 19:04:31 2018 LINKAGG info la_cmm_to_lani_send_conf_f event:Send CONF SYNCHRO to target slot 2
SUN SEP 02 19:04:31 2018 SSP_HELPER info SSP CMM : Sending EOIC to NI 2
SUN SEP 02 19:04:31 2018 LINKAGG info la_ni_rcv_nisup_f for slot:2, slice:0
SUN SEP 02 19:04:31 2018 LINKAGG info la_ni_mgt_rcv_ni_up_f for slot:2, slice:0
SUN SEP 02 19:04:31 2018 VLAN info Sent VM_CFG_RQT_DONE msg
SUN SEP 02 19:04:31 2018 VLAN info Rx VM_CFG_ACK_DONE msg from slot 2
SUN SEP 02 19:04:31 2018 VLAN info Tx VM_CFG_ACT_DONE to slot 2
SUN SEP 02 19:04:36 2018 STP warning SOK: Timeout Slot=2 Slice=0 seqID=x47 eventID=21 curRetry=0 maxRetry=25
SUN SEP 02 19:04:41 2018 STP warning SOK: Timeout Slot=2 Slice=0 seqID=x47 eventID=21 curRetry=1 maxRetry=25
SUN SEP 02 19:04:44 2018 LINKAGG info Responding to dynamic data req event: sender slot 1 target slot 2
SUN SEP 02 19:04:44 2018 LINKAGG info LA_DYN_DATA_RSP_OK event sent from slot = 1,target = 2
SUN SEP 02 19:04:47 2018 STP warning SOK: Timeout Slot=2 Slice=0 seqID=x48 eventID=21 curRetry=0 maxRetry=25
SUN SEP 02 19:04:48 2018 HSM-CHASSIS warning == HSM == RECEIVED NI_READY [2] from ESMDRV ...
SUN SEP 02 19:04:48 2018 HSM-CHASSIS info == HSM == Rcvd Ni2 READY from driver)
SUN SEP 02 19:04:48 2018 HSM-CHASSIS info == HSM == csHsmUtilNiCtxBrdSend() nsm CS_HSM_NSM_ST_OP, poweroff 0 Ni2
SUN SEP 02 19:04:48 2018 HSM-CHASSIS info == HSM == Clearing T.O. Flag on NI 2 when NI STATE READY
SUN SEP 02 19:04:48 2018 INTERFACE info RX CS_NI_READY NI 2
SUN SEP 02 19:04:48 2018 INTERFACE info NIs are ready
SUN SEP 02 19:04:48 2018 HSM-CHASSIS warning == HSM == NI [2] Request NI monitoring Start..
SUN SEP 02 19:04:48 2018 LANPOWER info Starting daughter module in slot 2!
SUN SEP 02 19:04:49 2018 PORT-MGR alert createObject: dup index
SUN SEP 02 19:04:49 2018 PORT-MGR alarm portav:port create failed!!
SUN SEP 02 19:05:03 2018 LINKAGG info Port Join . port: 2051 agg: 31
SUN SEP 02 19:06:22 2018 LINKAGG info Aggregate UP . port: 2003 agg: 2
SUN SEP 02 19:06:22 2018 LINKAGG info Aggregate UP . port: 2002 agg: 1
SUN SEP 02 19:06:24 2018 LINKAGG info Aggregate UP . port: 2005 agg: 3
SUN SEP 02 19:06:24 2018 LINKAGG info Aggregate UP . port: 2007 agg: 4
SUN SEP 02 19:06:24 2018 LINKAGG info Port Join . port: 2001 agg: 1
SUN SEP 02 19:06:24 2018 LINKAGG info Port Join . port: 2004 agg: 2
SUN SEP 02 19:06:26 2018 LINKAGG info Port Join . port: 2006 agg: 3
SUN SEP 02 19:06:26 2018 LINKAGG info Port Join . port: 2008 agg: 4
SUN SEP 02 19:13:21 2018 HEALTH info 1Hr avg. CPU usage exceeded 80
SUN SEP 02 19:14:48 2018 CSM-CHASSIS info == CSM == Stack topology changes have been updated to persistant file
SUN SEP 02 19:14:48 2018 CCM-CHASSIS info === CCM === NI 2 has been added to host 'vxTarget'
SUN SEP 02 19:14:48 2018 CSM-CHASSIS alert == CSM == csStackTopologyConfparse: retry 4
SUN SEP 02 19:14:48 2018 CCM-CHASSIS info === CCM === rcpp src [/flash/switch/stack_topology.txt] => dst[2:/flash/swi
SUN SEP 02 19:14:48 2018 CCM-CHASSIS info [Count.]tch/stack_topology.txt]
SUN SEP 02 19:14:48 2018 CCM-CHASSIS info === CCM === remoteSlot 2
SUN SEP 02 19:14:48 2018 CSM-CHASSIS info == CSM == PUT from:mySlot=65 myAddr=127.2.66.1
SUN SEP 02 19:14:48 2018 CSM-CHASSIS info == CSM == PUT to:Slot=66 addr=127.2.66.1
SUN SEP 02 19:14:48 2018 CSM-CHASSIS info == CSM == fromFile=/flash/switch/stack_topology.txt toFile=/flash/switch/stack_
SUN SEP 02 19:14:48 2018 CSM-CHASSIS info [Count.]topology.txt
SUN SEP 02 19:14:51 2018 STACK-MANAGER info == SM == No superv msg for last 20 sec. kickin SM flood msg in link B
SUN SEP 02 19:14:51 2018 STACK-MANAGER info == SM == Link B I: Qdisp Rx = 257582, SM_NI Rx = 354677, SM_DRV Rx = 177327 @ t
SUN SEP 02 19:14:51 2018 STACK-MANAGER info [Count.]ick 12468194
SUN SEP 02 19:14:51 2018 STACK-MANAGER error File Size exceeded for StackDebug.log
SUN SEP 02 19:14:52 2018 STACK-MANAGER info == SM == Superv Flood : REQ TX 1, RES TX 0, REQ RX 49, RES RX 0
SUN SEP 02 19:14:52 2018 STACK-MANAGER info == SM == All msg received by SM-NI from Q-DISP : 354677
SUN SEP 02 19:14:52 2018 STACK-MANAGER info == SM == Superv msg sent by SM-NI to SM-DRV : 354640
SUN SEP 02 19:14:52 2018 STACK-MANAGER info == SM == Superv msg received by SM-DRV from SM-NI : [A] 177313 - 177327
SUN SEP 02 19:14:56 2018 STACK-MANAGER info == SM == Stack Port B Status Changed: DOWN
SUN SEP 02 19:14:56 2018 STACK-MANAGER info == SM == Stack Port A Status Changed: DOWN
SUN SEP 02 19:14:56 2018 STACK-MANAGER info == SM == NI 2 down notification sent to LAG
SUN SEP 02 19:14:56 2018 LINKAGG info Port Leave . port: 2001 agg: 1
SUN SEP 02 19:14:56 2018 LINKAGG info Aggregate Down . port: 2002 agg: 1
SUN SEP 02 19:14:56 2018 LINKAGG info Port Leave . port: 2003 agg: 2
SUN SEP 02 19:14:56 2018 LINKAGG info Aggregate Down . port: 2004 agg: 2
SUN SEP 02 19:14:56 2018 LINKAGG info Port Leave . port: 2005 agg: 3
SUN SEP 02 19:14:56 2018 LINKAGG info Aggregate Down . port: 2006 agg: 3
SUN SEP 02 19:14:56 2018 LINKAGG info Port Leave . port: 2007 agg: 4
SUN SEP 02 19:14:56 2018 LINKAGG info Aggregate Down . port: 2008 agg: 4
SUN SEP 02 19:14:56 2018 LINKAGG info Port Leave . port: 2051 agg: 31
SUN SEP 02 19:15:02 2018 CSM-CHASSIS alert == CSM == Periodic checksum ACK not sent for ticks 3899 NI:2
SUN SEP 02 19:15:02 2018 CSM-CHASSIS alert == CSM == Periodic checksum not received for ticks 3899 NI:2
SUN SEP 02 19:15:18 2018 CSM-CHASSIS info == CSM == PUT:ftpXfer call error 3
SUN SEP 02 19:15:18 2018 HSM-CHASSIS info T8: Ni(2) extraction detected
SUN SEP 02 19:15:18 2018 HSM-CHASSIS info == HSM == csHsmUtilNiCtxBrdSend() nsm CS_HSM_NSM_ST_OP, poweroff 0 Ni2
SUN SEP 02 19:15:18 2018 HSM-CHASSIS info === HSM === Power Supply 2 has been REMOVED
SUN SEP 02 19:15:18 2018 VLAN info CS_NI_DOWN/CS_NI_NOTPRESENT msg Rx for slot 2
SUN SEP 02 19:15:18 2018 VLAN info Del connection for slot 2
SUN SEP 02 19:15:18 2018 VLAN info VMC: Sent Pause for slot 2
SUN SEP 02 19:15:18 2018 VLAN info Start Timer on ni_down 2 @ 1535933718
SUN SEP 02 19:15:18 2018 INTERFACE info Close NI 2 ESM, socket 226 OK
SUN SEP 02 19:15:18 2018 INTERFACE info Close NI 2 NiSUp, socket 246 OK
SUN SEP 02 19:15:18 2018 GM info NI_DOWN 2
SUN SEP 02 19:15:18 2018 GM info Del connection for slot 2
SUN SEP 02 19:15:18 2018 GM info GMC: Sent Pause for slot 2
SUN SEP 02 19:15:18 2018 GM info Start Timer on ni_down 2 @ 1535933718
SUN SEP 02 19:15:18 2018 LINKAGG info EVT board down received slot 2 slice 0 recover 0
SUN SEP 02 19:15:18 2018 ETHERNET-OAM info Timer started Slot: 2, SocketID: 495
SUN SEP 02 19:15:18 2018 PORT-MGR error portunav:Object 2049 does not exist.
SUN SEP 02 19:15:19 2018 VLAN info VMC: Disconnection from slot 66
SUN SEP 02 19:15:22 2018 VLAN info VMC: Disconnection from slot 66
SUN SEP 02 19:15:22 2018 VLAN info ret 0 Removed Timer @ 1535933722
SUN SEP 02 19:15:23 2018 GM info Timer closed skt on ni 1 @ 1535933723
SUN SEP 02 19:15:23 2018 ETHERNET-OAM info Timer expired Slot: 2, SocketID: 495
SUN SEP 02 19:16:05 2018 STACK-MANAGER info == SM == Stack Port B Status Changed: UP
SUN SEP 02 19:16:05 2018 STACK-MANAGER info == SM == Stack Port B MAC Frames TX/RX Enabled
SUN SEP 02 19:16:05 2018 STACK-MANAGER info == SM == Stack Port A Status Changed: UP
SUN SEP 02 19:16:05 2018 STACK-MANAGER info == SM == Stack Port A MAC Frames TX/RX Enabled
SUN SEP 02 19:16:09 2018 STACK-MANAGER info Retaining Module Id for slot 2 unit 0 as 2
SUN SEP 02 19:16:09 2018 STACK-MANAGER info Retaining Module Id for slot 2 unit 1 as 3
SUN SEP 02 19:16:12 2018 CSM-CHASSIS alert == CSM == P54_1 - Startup hold request received
SUN SEP 02 19:16:12 2018 CSM-CHASSIS alert == CSM == P54_1 - Forwarding Hold Status FALSE response to Secondary CSM
SUN SEP 02 19:16:15 2018 INTERFACE info Got connection from slot 2:226
SUN SEP 02 19:16:16 2018 CCM-CHASSIS info boot type message from slot 2 NISUP, boot type 1
SUN SEP 02 19:16:16 2018 INTERFACE info Got connection from slot 2:246
SUN SEP 02 19:16:25 2018 HSM-CHASSIS info T8: Ni(2) insertion detected
SUN SEP 02 19:16:25 2018 HSM-CHASSIS info == HSM == csHsmUtilNiCtxBrdSend() nsm CS_HSM_NSM_ST_OP, poweroff 0 Ni2
SUN SEP 02 19:16:27 2018 HSM-CHASSIS info === HSM === Power Supply 2 has been INSERTED
SUN SEP 02 19:16:27 2018 HSM-CHASSIS info == HSM == Power Supply 2 is OPERATIONAL
SUN SEP 02 19:17:02 2018 CSM-CHASSIS alert == CSM == Checksum rcvd from slot 2 in state 14
SUN SEP 02 19:17:02 2018 CSM-CHASSIS alert == CSM == Processing rcvd checksum 0x1bd53ee from slot 2
SUN SEP 02 19:17:02 2018 CSM-CHASSIS alert == CSM == Checksum matches, Slot 2 role CS_SECONDARY is in sync
SUN SEP 02 19:17:02 2018 HSM-CHASSIS info == HSM == csHsmUtilNiCtxBrdSend() nsm CS_HSM_NSM_ST_OP, poweroff 0 Ni2
SUN SEP 02 19:17:06 2018 GM info GMC: Got connection from slot 66, connIdx 1
SUN SEP 02 19:17:06 2018 VLAN info VMC: Got connection from slot 66
SUN SEP 02 19:17:06 2018 VLAN info VMC: Connected State will be in state 3
SUN SEP 02 19:17:06 2018 VLAN info MVRP_DUMMY_MSGID message received from NI, otherEnd = 9
SUN SEP 02 19:17:18 2018 HSM-CHASSIS info == HSM == NiNsmT1: NI STATE Rcvd (sl: 2), MsgFlag: 0 Local T.O. Flag: 0
SUN SEP 02 19:17:18 2018 HSM-CHASSIS info == HSM == NI UP Received from driver (sl =2)
SUN SEP 02 19:17:18 2018 HSM-CHASSIS info == HSM == csHsmUtilNiCtxBrdSend() nsm CS_HSM_NSM_ST_OP, poweroff 0 Ni2
SUN SEP 02 19:17:18 2018 VLAN info CS_NI_UP msg received for slot 2 cfgState 1
SUN SEP 02 19:17:18 2018 VLAN info CS_NI_UP InTakeover 0 vmcPrimaryCmm 1 NiDownRx 1
SUN SEP 02 19:17:18 2018 VLAN info CS_NI_UP State will be 3
SUN SEP 02 19:17:18 2018 VLAN info VMC: Sent Ok for slot 2
SUN SEP 02 19:17:18 2018 STP info STPCMM[7951]: sent config end to NI:2
SUN SEP 02 19:17:18 2018 ERP info ERP CMM[544] : Sending end of config from CMM to NI
SUN SEP 02 19:17:18 2018 GM info NI_UP 2
SUN SEP 02 19:17:18 2018 GM info GMC: Sent Ok for slot 2
SUN SEP 02 19:17:18 2018 LINKAGG info EVT board up received slot 2 slice 0 unlike 2 recover 0
SUN SEP 02 19:17:18 2018 LINKAGG info la_cmm_to_lani_send_conf_f event:Send CONF SYNCHRO to target slot 2
SUN SEP 02 19:17:18 2018 SSP_HELPER info SSP CMM : Sending EOIC to NI 2
SUN SEP 02 19:17:18 2018 LINKAGG info la_ni_rcv_nisup_f for slot:2, slice:0
SUN SEP 02 19:17:18 2018 LINKAGG info la_ni_mgt_rcv_ni_up_f for slot:2, slice:0
SUN SEP 02 19:17:18 2018 VLAN info Sent VM_CFG_RQT_DONE msg
SUN SEP 02 19:17:18 2018 VLAN info Rx VM_CFG_ACK_DONE msg from slot 2
SUN SEP 02 19:17:18 2018 VLAN info Tx VM_CFG_ACT_DONE to slot 2
SUN SEP 02 19:17:28 2018 LINKAGG info Responding to dynamic data req event: sender slot 1 target slot 2
SUN SEP 02 19:17:28 2018 LINKAGG info LA_DYN_DATA_RSP_OK event sent from slot = 1,target = 2
SUN SEP 02 19:17:28 2018 HSM-CHASSIS warning == HSM == RECEIVED NI_READY [2] from ESMDRV ...
SUN SEP 02 19:17:28 2018 HSM-CHASSIS info == HSM == Rcvd Ni2 READY from driver)
SUN SEP 02 19:17:28 2018 HSM-CHASSIS info == HSM == csHsmUtilNiCtxBrdSend() nsm CS_HSM_NSM_ST_OP, poweroff 0 Ni2
SUN SEP 02 19:17:28 2018 HSM-CHASSIS info == HSM == Clearing T.O. Flag on NI 2 when NI STATE READY
SUN SEP 02 19:17:28 2018 INTERFACE info RX CS_NI_READY NI 2
SUN SEP 02 19:17:28 2018 INTERFACE info NIs are ready
SUN SEP 02 19:17:28 2018 HSM-CHASSIS warning == HSM == NI [2] Request NI monitoring Start..
SUN SEP 02 19:17:28 2018 LANPOWER info Starting daughter module in slot 2!
SUN SEP 02 19:17:43 2018 LINKAGG info Port Join . port: 2051 agg: 31
SUN SEP 02 19:19:02 2018 LINKAGG info Aggregate UP . port: 2003 agg: 2
SUN SEP 02 19:19:02 2018 LINKAGG info Aggregate UP . port: 2002 agg: 1
SUN SEP 02 19:19:04 2018 LINKAGG info Port Join . port: 2001 agg: 1
SUN SEP 02 19:19:04 2018 LINKAGG info Aggregate UP . port: 2005 agg: 3
SUN SEP 02 19:19:04 2018 LINKAGG info Aggregate UP . port: 2007 agg: 4
SUN SEP 02 19:19:04 2018 LINKAGG info Port Join . port: 2004 agg: 2
SUN SEP 02 19:19:06 2018 LINKAGG info Port Join . port: 2008 agg: 4
SUN SEP 02 19:19:06 2018 LINKAGG info Port Join . port: 2006 agg: 3
SUN SEP 02 20:01:40 2018 TELNET info New telnet connection, Address 10.1.1.100
SUN SEP 02 20:01:40 2018 TELNET info Session 6, Created
RHS IDF FRONT POD STACK .180->
