Using LOLQa
et
Re: Using LOLQa
Post by et »
In upper part of window LoLa you can see "File Language View Help". In the "Help" you see "Online Help". Or press "Help" button in lower part of LoLa window.
steg81_DUP
Re: Using LOLQa
Post by steg81_DUP »
Thanks heaps matey
bjvickstar
Re: Using LOLQa
Post by bjvickstar »
since add hd to cpu-2 or -3 that use lola ????
et
Re: Using LOLQa
Post by et »
After installing Hd on CPU-2(3) you will see the migration process from flash to HD. After that all is working, but better way is - to use LoLa.
laroth
Re: Using LOLQa
Post by laroth »
Krusty65 wrote:Most of the time the issues with LoLa are due to the samba share not setting up properly. Two things you can try are
1. Switch on the trace mode on the CPU (via V24 type 'swap_serial' with 'letacla' as the password) and then reset this will give you more info as to what is causing the failure.
2. In windows set up a full share on the directory that you have the sw in.
**** I do not have a V24 cable, but I get a telnet login on the CPU in Lola mode, any idea og the username/password here, I had hoped that I could debug / trace from this interface as well.
Laroth
Krusty65
Re: Using LOLQa
Post by Krusty65 »
The V24 cable pin outs are in the manual but it is the same as the RMA cable for the OxE.
Another option is using the webapp login
https://"your oxo ip address"/services/webapp/monitor. One of the options in there is swap serial.
I won't post the login and password as Cav will jump on me :D but they are in the tech docs (I think there is also a TC for this but don't quote me on that one)
How ever if you don't have a serial cable the swap will do absolutely nothing to help as you will not be able to see the trace output
Return to “MAIN”
