CCO migration to virtual machine made a lot of 1 second calls
idtasov
Re: CCO migration to virtual machine made a lot of 1 second calls
Post by idtasov »
Nothing different with VAD ..... +true and timers ajustments.
I will try OXE downgrade from h130150a to h130134a as it was before disaster.
Wait what? So you blame CCO when you also messed with OXE? It is always better to do a change at a time only to have a better control
idtasov
Post by idtasov »
At the end I upgraded PBX to ...50c dinamic patch. Now all CCO works as never before - all timers are sensitive and impact the system and can ajust it. :)
idtasov
Post by idtasov »
idtasov
Post by idtasov »
Do somebody know how to distinguish who send the command to CCA. There is thirth party software using SDK SWL of CCA and there is some CCA avalibility timing?
sadim
Post by sadim »
Perhaps setting setting SdkClassesDebug=1 on cca.ini file
Return to “OmniTouch Contact Center Standard Edition”
