Quoting new 4059IP
tincho.rn
Re: Quoting new 4059IP
Really don´t know what that is happening. I can tell you that I have disable many times the PC for the Attendant or any other application (4760, CCA servers,...).
Ihthisham
What is the Actis version u are using?
in Actis 11.2.2 u could remove the PC rquirement.
tincho.rn
I just recently test with ACTIS 11.2.0. Go to Applications --> Attendant (I am traslating from spanish, I don´t know if this are the exactly words). Then, where you have the PC for each application (for example: CCS, CCA Server, 4059, ...), in the column PC, double click over PC-01 (for example). There you shuld have the option to deselect the PC.
If you whant to deselect the PC for the 4059, take into account that Alcatel only gives support for certain type of PC (some models of HP and others that I don´t remember). Read technical communication about this. Regards.
Ihthisham
Sorry I was asking that question from torrentula...Infact I thought ACtis 11.2.0 is giving trouble.
anybody can translate the spanish in to english..what's the error popping up?
torrentula
I was using 11.2.0, I can't remember the error and am now on 11.3.0. Not an issue anymore, we sold them a standard 4059 anyways. I will try in 11.3 and see if I have the same problem.
torrentula
They have fixed this in 11.3. By default you get no pc, but have option to add it.
Eliott_DUP
Yes, but 11.3 had another ugly bug but I can't remember which one
torrentula
Yeah, they jacked up the catalogue database, so now every order we send in to AL, the numbers don't match. Then they sent out a new database that just made problems worse
Fixing one problem with another, I guess I should be use to this by now
