2 strange problems
IceMan_DUP
Post by IceMan_DUP »
Thanks aurelian,
I will give it a try when this problem happens again.
multumesc :)
goofy
Voicemai Indicator light flashing but no message
Post by goofy »
Under Users extension number and Voicemail Directory Number, delete/remove the vmail pilot number and save/apply the changes.
Then re add/apply the Pilot number and save.
This will get rid of the Voicemail indicatior light
kikpal
Post by kikpal »
i have the voice mail problem on 4020
goofy
Post by goofy »
Hi Kikpal
On MGR or 4760
André
Post by André »
For callback issues there is a command callbstat so you can see the status of a phone. But unfourtunatly I don't know a command for resetting a callback call on the cpu.
freedom
Post by freedom »
André wrote:For callback issues there is a command callbstat so you can see the status of a phone. But unfourtunatly I don't know a command for resetting a callback call on the cpu.
The correct solution was already given by aurelian.
If you use the prefix 'Access Callback List' the callback action will be deleted.
IceMan_DUP
Hi all,
Actually this problem still exsists.... So the solutions mentioned above are not working :cry:
If anybody has an idea please share it with me and release me from my sleepless nights.... :lol:
IceMan
juanattack
Post by juanattack »
Hello.
Maybe its a text message which hasnt been deleted...
mgoegel
Post by mgoegel »
Simply start mgr, consult sets port data (Shelf/Board/Port) and write it down.
Then set the address to 255/255/255 and apply it.
Now you restore the port settings to the set and all should be ok.
Mario
zanex
Post by zanex »
To find out why the lamp is on you can use a couple of tools
If it is a callback
(1)Test> callbstat d 2918
idx_rappel 1 for set 2918
zone : etat : nulog/numan/neqt Key: typ_rap
Adress of the area 1 : 0x12a15bac
1 BUSY 322 -1 RAPMOI
2 FREE
3 FREE
4 FREE
5 FREE
6 FREE
7 FREE
8 FREE
Message Led 1 Message is present 1
Note : neqt/nulog/nugroup/numan depends on the typ_rap data
: Be Careful neqt is used for CCBS_
RAPMOI means that it is a callback from nulog 322
To find out what xtn it is
(1)CA_cpuB> postlog 322 |grep numan
neqt=1198; numan [1..8] = 2547 nomannu[length=10] = USER Test
If it is a VPS voicemail message lamp
(2)Test> callbstat z idx 1
idx_rappel 1 for set 1234
1 BUSY 55 -1 VCM_VOC
2 FREE
3 FREE
4 FREE
5 FREE
6 FREE
7 FREE
VCM_VOC means set from VPS - although it doesnt always show up and sometimes you have to use zdpost to see. I am not sure why this is though
For some VPS (tested with repartee) and 4635
(1)Test> zdpost d 2918 |grep Mail
Mailstatus.Voice.Number = 1 no of messages
Mailstatus.Voice.Age = 0
Mailstatus.Fax.Number = 0
Mailstatus.Fax.Age = 6
Mailstatus.Textnumber.Number = 0
Mailstatus.Textnumber.Age = 6
Mailstatus.Cabacknumber.Number = 0 no of callbacks
Mailstatus.Cabacknumber.Age = 6
Mailstatus.CNA_interne.Number = 0
Mailstatus.CNA_interne.Age = 6
To clear callback just virtual (255) it or user the consult callback list prefix for the xtn, for voicemail you have to go in and clear out the messages.
There is also a Local Features + Switch off Message LED prefix that can be useful
Return to “ON SITE TROUBLES”
