ESXI 5.5
2Gb of Ram 1 CPU for each VM.
vSR on VMWare Workstation
helmi
Re: vSR on VMWare Workstation
Hi All.. I'm facing the same problem. Is there anyone knows how to fix this. Appreciate if you could share. Thanks.
Post your config details (detailed) and exact error. Screenshots would be great
lrj
I am trying vsr installation, and it is stuck at boot. I am using 14.0R4 , in VMware player. I tried with 14.0R3 also, and it is giving the same result.
Can someone please help?
Thanks.
Thanks.
muneer_se75
tahts that's the standard as Nokia routers don't respond to VGA ports. What you need to do edit the VSR VM settings add serial port. In serial port you will find PIPE URL. Just copy that URL open putty select serial and paste that URL you will be able to access the console of VSR VM.
