Regstering problem of 8082 with OXO R9
Re: Regstering problem of 8082 with OXO R9
Certificate has nothing to do with 404 error
Oxo hasn't created the xml file. You are missing the step of mac registration. Follow the guide step by step
aw-au
Post by aw-au »
i know, last replay is few years old, sorry.
I have a problem, same here,
i try to connect 8082 to OXO
I also think that OXO has not created xml-file
Phone ist nor registered in the moment in the list of the hardware-members were all the other phones are in.
i have connected two Deskphones 8082 - both work fine and as i wish.
so there ist a difference between the 8082 and the 8028. working 8028 meens not that the configuration of the oxo is also working für 8082 correct?
what can i do to check if xml file is present?
thanks!
rkraehen
Post by rkraehen »
Hi aw-au, check if on the OXO the "VoIP Protocol" is set to SIP, IP licenses and My IC Phone software package are present. Check if DHCP is activated on the OXO. Plug the 8082 on the LAN.
If not ok you might try to setup manually the following parameters. Create a new IP user with type = "OmniTouch 8082 My IC Phone". In the Details/IP-SIP Parameters of the created user set the Mac adress of the 8082. Check that 8082 network settings are set to DynamicAlcatel. Still not ok, search for a trouble shooting guide on Alcatel-Lucent Enterprise Business Portal.
aw-au
Post by aw-au »
Hi rkraehen,
thanks for your reply and sorry for my late answer, i was working on other projects.
The (try of) installation of some phones is a work that i do if there is time and i dont have projects.
after 29-11-2019 and before i was reading your comment i tried another phone, 8068, also in thsi case
its not working. but that might be worth another case, even if it has the same cause for not working / connecting to the OXO.
What i can say and back to the case here,
yes, the VOIP-protocol is set to SIP
Ip licenses, don´t know where to control / check this?
My IC Phone software package? should be in german under "teilnehmer verschiedenes" / maybe in englisch menü: members misc. or so.
there is a pop-up-menü, whre i can see my ic applikations, in my case, windows are empty;
DHCP ist not activated in any menu i could find DHCP settings. i think thats because my DHCP - server is one of our windows-servers. an i´, afraid to active a DHCP-Server in OXO, cause i know that if you have two DHCP-servers in one network that might be crashing.
But i think, anyway i would like to configure the ip phones manually, the both 8028 we have running with are also configured with static IPs.
So like you said, i might try to set up manually, i have created a new IP user but it has not the name you told me, is that a problem (you said: "OmniTouch 8082 My IC Phone" ); i have set the MAC-adress of the 8082, now i have to control if IP-settings of the phone are set to fixed parameters, or dynamic or dynamicalcatel. i will answer what is working. thanks
Lolo31560
Registering problem of 8082 with OXO connect R4
Post by Lolo31560 »
It seems that the Alcatel 8082 set is no longer compatible with the oxo connect R4.
Yet it is still referenced in the release note of the last connect version of January 2021.
Anyone have a solution for my client?
I have to upgrade the oxo, so do a migration because the oxo is in R9.2
It would be a shame to lose the functions that the customer uses, namely the video presentation of a call from the IP doorphone from castel.
Thank you !!!
Julien_fr
Post by Julien_fr »
TC2723 ed.01:
"However, the 8082 My IC phone can still be connected to OXO, thanks to a new noteworthy address in OMC :
 OMC -> System Miscellaneous -> Global System Parameters -> “allow_MYIC_Phone_8082” : false / true.
System reset is required to take into account the configuration change."
I didnt test it.
I will try
