Network TDM DR-Link recording problem
ejuanillo
Re: Network TDM DR-Link recording problem
Post by ejuanillo »
Hi edpaternina,
I finally manage to avoid SECURITY_VIOLATION error while recording remote device using your aproach (cristal Number + 128).
However i have same problem you have.
No audio from PCM board in remote devices recordings.
Local devices recording works fine but still no success with remote ones.
Do you make any progress or have any other clue?
Something we can test?
Thanks in advance.
Regards, J.
ejuanillo
Post by ejuanillo »
No success yet.
I could get some CSTA traces but i don't see anything relevant.
Traces from both nodes seem very similar to me.
I've attached both log files.
Maybe somebody could see something.
I'm wondering ig the "+128" approach could be hiding some problem.
Maybe "SECURITY_VIOLATION" error is raising for other reason, and adding 128 to cristal number in startListening API call is just bypassing this error, but as the error is still there, audio can't reach local node.
I don't know...
Thanks in advance!
Regards, J.
Return to “TSAPI”
