load the software that is on the DVD onto a PC (they usually have DVD drives) and use the application to serve via ethernet (the CS has an ethernet port).check the DVD and you should find an application called "PC installer". install that to a PC and the use it to serve the CPU 6 via ethernet.
PS watch out for netbooks as they come without DVD drives.
