6850 - 802.1x SNMP
fattyc
Re: 6850 - 802.1x SNMP
Post by fattyc »
Hello Cedric,
Not sure if you monitor old threads,
Can't seem to get saem result as you even though I have upgraded to the latest version .
I am currently running the following code 6.4.3.751.R01.
I have swlog setup , swlog appid 20 level info.
Then looking for supp and non supp failures.
I see logins but no failures.
Could you do me a favour ? May I ask if you had any special logging set ???
cedric1
Post by cedric1 »
hello
I will check , but my level is info and 802.1X accounting mac local
Can you send me your config output for accounting
Cedric
fattyc
Post by fattyc »
Thanks for the replay Cedric and hope you are well .
My RADIUS accounting
aaa accounting 802.1x local
aaa accounting mac local
swlog appid AAA level info
swlog output socket 192.168.56.134
swlog remote command-log enable
swlog console level info
cedric1
Post by cedric1 »
hello
I'm well, thanks but was very buzy last time.
Here my output on my system witch is a 9000 switch.
242=> show log swlog
Displaying file contents for '/flash/swlog2.log'
FILEID: fileName[/flash/swlog2.log], endPtr[60], configSize[500000], mode[2]
Displaying file contents for '/flash/swlog1.log'
FILEID: fileName[/flash/swlog1.log], endPtr[768], configSize[500000], mode[1]
Time Stamp Application Level Log Message
TUE JUN 14 21:30:04 2011 SYSTEM info Switch Logging cleared by command. File Size=1000000 bytes
TUE JUN 14 21:30:48 2011 AAA info AAA logout,001D092C1A85,MAC,cause=0038,01/22,00:1d:09:2c:1a:85,
TUE JUN 14 21:30:54 2011 AAA info AAA failure,001D092C1A85,MAC,cause=0038,01/22,00:1d:09:2c:1a:85,
TUE JUN 14 21:31:02 2011 AAA info AAA failure,001AE8074C91,MAC,cause=0038,01/22,00:1a:e8:07:4c:91,
TUE JUN 14 21:31:14 2011 AAA info AAA login,001599064271,MAC,,01/22,00:15:99:06:42:71,
TUE JUN 14 21:31:23 2011 SSH info Session 1 New SSH Connection from 10.172.1.5 port 29390
TUE JUN 14 21:31:24 2011 AAA info AAA login,admin,SSH,,session=001,10.172.1.5
TUE JUN 14 21:31:30 2011 AAA info AAA logout,admin,SSH,cause=0000,session=001,10.172.1.5
TUE JUN 14 21:31:32 2011 SSH info Session 1, Session Deleted
242=> show swlog
Operational Status : On,
Log Device 1 : flash,
Log Device 2 : console,
Log Device 3 : ipaddr x.X.X.X,
Syslog FacilityID : local0(16),
Remote command-log : Disabled,
Console Display Level : debug3 (9),
All Applications Not Shown Level : info (6)
Application ID Level
SESSION ( 71) off (1)
242=>
242=> show microcode
Package Release Size Description
Jbase.img 6.4.3.751.R01 22164829 Alcatel-Lucent Base Software
Jadvrout.img 6.4.3.751.R01 2875942 Alcatel-Lucent Advanced Routing
Jos.img 6.4.3.751.R01 2159650 Alcatel-Lucent OS
Jeni.img 6.4.3.751.R01 6543803 Alcatel-Lucent NI software
Jsecu.img 6.4.3.751.R01 587665 Alcatel-Lucent Security Management
Jencrypt.img 6.4.3.751.R01 3437 Alcatel-Lucent Encryption Management
Jdiag.img 6.4.3.658.R01::haganap 3306245 Alcatel-Lucent Diagnostic Software
Jrelease.img 6.4.3.658.R01::haganap 3145 Alcatel-Lucent Release Info Archive
fattyc
Post by fattyc »
Mine is exactly the same 'cept it;s on a 6850.
Think I may need to pass this onto Alcatel TAC.
Cedric
cedric1
Post by cedric1 »
yes, one bug less.
