AHL Simulator over V24
Re: AHL Simulator over V24
Re-posting the AHL Simulators.
Username and Password for AHL Simulator over IP is the same as OXE's (mtcl).
Hi ccube
Thank you very much for spenting you time posting the files.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
Thanks for the simulators ccube. Was desperately looking for it. Thanks again.
There is no lift to success.You have to take the stairs - one at a time.
I need some help. When I try to AHL.exe file, the system is giving me a runtime error 76 message. Followed installation instructions given and all went according to what the install doc says but as soon as I try to run the .exe file, I keep receiving the error. Have tried to unzip the whole simulator file into C: but still no change.
Has anyone tried this simulator working before? Can you tell me what I am missing here.
Appreciate your help.
Siti
Siti
Hi Siti,
Runtime error 76 is "Path not found". The simulators woks fine and I've just recently installed it on Windows 7 Professional 64-bit without any problems. You may have missed out something on the procedure.
IvanP
Hi Siti,
did you got the solution for the Runtime 76 error?. I'm broken my head trying to solve it in an XP but I've been unable at the moment.
Thanks a lot
Ivan.
Thanks a lot
Ivan.
Hi Ivan,
Which AHL Simulator are you trying to install? Is it AHL v1 or AHL v4.5 (old one)?
IvanP
Hi ccube and thanks for your interest.
I've installed both. I thought 4.5 was for V24 simulation and v1 for AHL over Ethernet. The 4.5 version opens correctly after installation. For v1 installation I've followed the instructions in the pdf, registered the four 'dll's but when I execute it, I got a Runtime error 76. I think it's not necesary to have any Visual Studio to run the emulator.
I'm trying to communicate my app with a AHL telephone center over IP. I haven't access to the real telephone center until installation time so I need the emulator to implement and test the AHL protocol in my code.
Maybe just by creating the path the application is trying to access will work it out but I'm feeling more and more into the mud.
Ivan
PS: Version 4.5 cannot be used for listening on a IP port, can it?
Ivan
Hi Ivan,
I think version 4.5 can be used for AHL over IP though I have never tried it before. I always use V1 for AHL over IP. Is the AHL folder on Drive C (C:\AHL)? Runtime error 76 appears when AHL folder is not on Drive C.
ccube
ccube
