Mobile interface problem
charliebrown408
Post by charliebrown408 »
First you have to check hardware configuration of the connected media, and also casing of the connectors. If it is OK then you can connect to other devices.
Now suppose if still problem occurs then you have to reinstall all the supported software for connecting the mobile.
Return to “Hardware”
