mustafa.ahmad wrote:if there are two extensions running on the same cable, then make one of the extns out f serv. by givin shelf, board, eqpmnt addrss as 255.
then establish call to other extn, if the problem is resolved, then u will hv to shift one f the digital extn to another cable.
Yes, for the digital we only can use 25 pairs from 50 pairs multiple cable, caused if all the pairs used then the handset won't function, one pair used next pair doesn't, and so on,........
But still the noise heard,........
