Multi session-telnet emulator
What country in the world would forbid encryption !?
Mr T
Post by Mr T »
This may be an outdated list, but this is what I could find of countries that have banned or restrict encryption:
Cuba, Iran, North Korea, Syria, Burma, Belarus, China, Morocco, Russia, Saudi Arabia, Tunisia, Ukraine.
Some of these countries make you apply for a license, so not completely banned, but restricted. Others completely forbid it.
Must be a heaven for hackers.
Thanks though !
nperalta
Post by nperalta »
Secure crt
freedom
Post by freedom »
I'm not sure if SecureCRT is a solution if putty isn't allowed.
It's a great piece of software that could be used for multiple telnet sessions in one screen, but also supports ssh.
So if you're not allowed to use putty, you probably have the same issue with SecureCRT.
Another con for this software is that it isn't freeware! You have to purchase a license to be able to use it on www.vandyke.com
swinstation
Post by swinstation »
wooooooow we lost main mile.forget about my question
GembuL
Post by GembuL »
Vandyke SecureCRT
this is a good stuff,better than putty for me. search in google for the crack/keygen. *LOL
swinstation
Re: Multi session-telnet emulator
I find ZOC Terminal very good software for making multi session (telnet) please try it.
it is very useful for networked pbx.
FN_DK
Post by FN_DK »
Hola,
I have always been using Putty. Its quits simple and easy to use, but it does not hold many extra features.
Therefor I went googlehunting and found "Xshell" Check it out here: http://www.netsarang.com/products/xsh_overview.html
Best terminaltool I have ever used.
- Auto login/password on the OXE
- Auto timout 0
- Auto triggers any script you set
- Hold as many sessions as you want
- Customizied bar for shortcut keys. incvisu, trkstat, sipregister, swinst, you name it.
and no, I dont work for em...
Return to “Other Alcatel-Lucent tools”
