OXE PC Installer startup
REMOVE ALL VPN
Disable all internet interfaces but the local one
uninstall PCINSTALLER
remove directories
remove registry settings
reboot
install new release
let us know..
patmul39
Post by patmul39 »
:confused:
had to load a couple of CPU's yesterday and I thought what the heck - gice it a try and the damned thing worked!!! And to amaze me even more I had my VPN up and working, anti-virus etc. I can't understand this - and I did nothing to the machine!!
murraya
Post by murraya »
sure you didn't reboot :)
I have always found it best to make sure the PC is connected to the network before starting the installer so that the NIC is up as I have had issues in the past when I run the installer then connect the NIC.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
OXE_4400
Post by OXE_4400 »
frank wrote:REMOVE ALL VPN
remove directories
reboot
install new release
let us know..
Everything mentioned was done, a lot of PC restarts, different versions. I have opened SR.
I am going to buy new faster HDD and reinstall PC...
Will try to install PC installer version 2.26, it should appear with R9.1 patch 13.
ok, let us know..
patmul39
Post by patmul39 »
murraya wrote:sure you didn't reboot :)
No reboots! It just worked!
zaenuddin
Post by zaenuddin »
I have the same problem , i think the problem is from installer at R 9.1 ,because with the old release ( 9.0 ) working Fine .
for others you can try to install new PC Installer from release 9.1 ( i160512) ,and you will know the real problem,you cannot uninstall it.
Please let us know if some one have solve this problem ?
alex
Post by alex »
zaenuddin wrote: Please let us know if some one have solve this problem ?
Strange. I did a couple of times install/uninstall of 2.25-pre when was playing with my new HP 6730b notebook and Windows 7 Pro x86.
There were no problem at all. Of course you should switch off Windows firewall to load SW but except that everything was OK.
So I think it is PC HW+OS setup specific problem.
OXE_4400
Post by OXE_4400 »
ALU support provided solution for problem. It was changed value in registry HKEY_LOCAL_ MACHINE\SYSTEM\CurrentControlSet\Control\FileSystem\NtfsDisable8dot3NameCreation to 1.
It should be 0. Changed back, uninstalled PC installer, restarted PC, installed even newest 2.26 version and everything OK.
aalmanzar
Post by aalmanzar »
I tried installing the PC installer 2.22, 2.24, and even 2.26. when I double click on the set up shortcut nothing happens. It was working fine when I had 2.11 but because I need it now I UN-installed 2.11 to install 2.26, now my PC is not allowing me to install the PC installer software. Any ideas???
Return to “Software Loading”
