Name not display
A H323 and SIP forum only !
mdhussainvlr
Re: Name not display
Post by mdhussainvlr » 06 Oct 2018 13:02
Sure Cav
mdhussainvlr
Post by mdhussainvlr » 07 Oct 2018 07:39
I changed true but still content length showing 0
mdhussainvlr
Post by mdhussainvlr » 08 Oct 2018 15:06
Is it possible from at least OXE side to set the P-asserted identity in the invite SIP mesage to Avaya Phone ?
How come Phone shows name and number when making outbound calls from SIP to SIP (both Avaya) or SIP
to NOE ??
Somebody can help me on this
Post by cavagnaro » 08 Oct 2018 15:18
Again, when you do a call from a sip set, it is the sip set who build the invite command. So if the set doesn't provide specific info, you have to ask the sip set manufacturer. OXE will just receive the invite and forward it to the corresponding target. OXE will manipulate via SIP external gateway only when, as name indicates, the target is external to the OXE.
So, if Avaya is missing some information, you need to ask them how to configure the set for those parameters you want.
mdhussainvlr
Post by mdhussainvlr » 08 Oct 2018 23:42
I will check with Avaya & update you CAV
mdhussainvlr
Post by mdhussainvlr » 11 Oct 2018 13:38
Finally I checked with Xlite with OXE
and Avaya with OXE
Timothyhek
Name not display
Post by Timothyhek » 01 Feb 2019 10:06
I am also facing the same problem. I have a Nokia N73 from Asia and it does not show the name of the caller in Canada. It just shows the number. I am kind of furstrated with this issue. Tired calling Nokia about this and it turned out to be of now use... any other uses facing the same problem? Any suggestins to get this fixed....
thanks.
Return to “H323 / Sip”
