Good afternoon
I need to input snmp-agent communications into Alcatel switch.
I have this model below that I use on my hp switches.
How do I transcribe this information for SW Alcatel OS6860E?
Can anybody help me?
snmp-agent
snmp-agent local-engineid 800063A203CC3E5F27FCEA
snmp-agent community read public######
snmp-agent sys-info contact security@####
snmp-agent sys-info location ######
snmp-agent sys-info version v2c v3
snmp-agent group v3 NT privacy
snmp-agent usm-user v3 snmpNT cipher authentication-mode md5 $c$3$V2KhDFBC6v1YVuGfdbjZZxOLC9X1eQs9iXcO/746OypojA== privacy-mode des56 $c$3$kGSz26Zl0/ld0AOKhHYiCj9JmCDNq7CD==
Snmp-agent Switch Alcatel
Re: Snmp-agent Switch Alcatel
you don't need to activate anything - snmp agent is running. The ip service snmp is active per default. So you use only to activate the access via the "aaa authentication" command and you need a "normal" user with the necessary rights and the used method (f.e. sha+des).
Dear,
Good Morning
I'm still having trouble implementing SNMP, SYSLOG they don't communicate with the server.
What do I need to do to get this switch to communicate with snmp v2?
Can someone help me?
Below is the configuration.
! Trap Manager:
snmp station 172.100.0.20 161 "public###@@@" v2 enable
! SNMP:
snmp security no-security
snmp authentication-trap enable
snmp community-map mode enable
snmp community-map hash-key c47fdc198d69417e user "public###@@@" enable
! AAA:
aaa authentication http "local"
aaa authentication snmp "local"
! System Service:
swlog output socket 172.100.0.30
Good Morning
! Trap Manager:
! SNMP:
! AAA:
! System Service:
you know the community for the configured hash-key?
Is there a user "public###@@@" with read-write (or read-only) all no auth?
Hello, Silvio!
Yes, i know
In the case of the company, it would be read-only without authentication!
Could you tell me how to proceed?
Yes, i know
your community is maped to this user. So the rights for the community are comming from this user.
in case of snmp-v1/v2 (very unsecure - not recomended) the user needs "read-only all no auth".
command: user public###@@@ password not-Important123 read-only all no auth
I prefere to use snmp-v3.
Thank you Silvio.
It worked.
It worked.
