Iflastchange
aviviis
Iflastchange
Post by aviviis »
Can you explain the OID iflastchange on os6860 port ?
I make port up and down but when i check with snmp object of iflastchange i see that the time on port is 109 days ...
Re: Iflastchange
which uptime did you see with cli command "show interface x/x/x"
Is it the same wrong time?
aviviis
Re: Iflastchange
Post by aviviis »
So what is the meaning of the result of cli command show interface 1/1/5 , when i see at the field
Last Time Link Changed
devnull
Re: Iflastchange
Post by devnull »
That should be the time, when the interface last changed. e.g link went up (or gone down)
aviviis
Re: Iflastchange
Post by aviviis »
Thx
