NAT/NAPT in OmniAccess ESR
moonb0w
Post by moonb0w »
Hello guys,
I've been spending 2 days to enable PAT in OmniAccess ESR. This router has 1 upstream connection to ISP router and 1 downstream connection to LAN.
I would like to do simple PAT so the LAN can access internet, but the doc just cover to translate one particular port to another port.
Really appreciate for your help :)
Here's the config:
 network ethernet0/0
; -- Ethernet Interface User Configuration --
      ip address 100.95.32.10 255.255.255.252
   exit
   network ethernet0/1
      ip address 10.71.4.2 255.255.255.0
   exit
   network ethernet2/0
      no auto-negotiation
      duplex full
      speed 1000mbps
   exit
   network ethernet2/1
      no auto-negotiation
      duplex full
      speed 1000mbps
   exit
   protocol ip
; -- Internet protocol user configuration --
      route 10.71.0.0 255.255.0.0 10.71.4.1
      route 0.0.0.0 0.0.0.0 100.95.32.9
      rule 1 local-ip ethernet0/1 remote-ip 100.95.32.10
      nat pat
; -- NAPT configuration --
         visible-port 0 rule 1 ip 0.0.0.0 port 0
         subnet 100.95.32.10 255.255.255.255 rule 1 default
         subnet 100.95.32.10 255.255.255.255 rule 1 gateway 100.95.32.9
      exit
   exit
Return to “OmniAccess ESR 5720”
