Hi Everyone,
Wondering if someone could help me. I currently have a OT Solution on R2.2 and I am trying to get my OTC Android working. The Reverse Proxy on NGIX+ is configured and also the SBC is correctly configured and when logging on I can see the android device successfully connecting to the SBC. I can dial other internal extensions and can dial the android device ok as well. The only problem I am having is that the display on the android device is not updating so if this is an incoming call the phone rings but you are unable to answer the call as the screen does not change to indicate an incoming call. This is the same on an outgoing call.
The speech is fine on the calls the issue is just with the display on the Android phone not changing on incoming and outgoing calls.
Thanks everyone.
